Hello all,
I'm searching for an input deck (minimum example) to solve the below mentioned problem:
- system to be analyzed: two bodies connected with a spring
- Fit simulated transfer function of the given system to a measured transfer function of this system while optimizing the K- and GE-Values of the connecting spring (CBUSH-Element).
Can anyone help out here?
Kind regards
