<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="198" width="522"> <operator activated="true" class="read_csv" compatibility="5.2.003" expanded="true" height="60" name="Read CSV" width="90" x="80" y="20"> <parameter key="csv_file" value="/home/cjfpainter/deviceQuery.txt"/> <parameter key="column_separators" value="\n"/> <parameter key="trim_lines" value="true"/> <parameter key="use_quotes" value="false"/> <parameter key="parse_numbers" value="false"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <connect from_op="Read CSV" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
