Thanks for discussion guys. I have the same problem
can't load ia 32-bit.dll on a AMD 64-bit platform
You mentioned jri.dll should be
rJava\jri\x64\jri.dll
I try to select that. But RM doesn't let me - when I click "select JRI library file", it just tell me it has found one...
Could somebody tell me how to manually set that up? Thanks
please note that what you posted is the old R extension which was replaced with R Scripting as of RapidMiner Studio 6.4 and later because of the tedious and error-prone setup.
I would highly advise using the new extension instead with the latest RapidMiner Studio version (7.2).
Marco
