Hello!
I'm very aware of the fact that it's not being welcomed to ask questions regarding the chaining of operators programatically. However, I need to do this for my thesis and hope that you'll kindly oversee it this time.
Everything works really well already, but I couldn't figure out how to connect the output of an operator to a result port of my process. Could anyone give me a hint? It's this part:
I tried to look for ports of the RootOperator, but there was no output:
System.out.println("looking for process ports");
for (String port : process.getRootOperator().getInputPorts().getPortNames())
System.out.println(port);
Am I able to add it anyway? Or somewhere else?
The actual problem I have is that after the process finished, I can't access the result (because there is none, I guess).
INFO: Process finished successfully after 3 s
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at java.util.ArrayList.rangeCheck(ArrayList.java:570)
at java.util.ArrayList.get(ArrayList.java:348)
at com.rapidminer.operator.IOContainer.getElementAt(IOContainer.java:112)
at BackendTest.main(BackendTest.java:128)
At this line:
if (process_result.getElementAt(0) instanceof ExampleSet) { ... }
Thanks in advance!
