<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.002"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.002" expanded="true" name="Process"> <process expanded="true" height="415" width="614"> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document" width="90" x="112" y="30"> <parameter key="text" value="bla bla"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document (2)" width="90" x="112" y="120"> <parameter key="text" value="bla blu"/> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document (3)" width="90" x="112" y="210"> <parameter key="text" value="blu blo bla"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.2.001" expanded="true" height="130" name="Process Documents" width="90" x="313" y="30"> <process expanded="true" height="472" width="923"> <operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="397" y="90"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document (4)" width="90" x="313" y="345"> <parameter key="text" value="bla blu ble"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.2.001" expanded="true" height="94" name="Process Documents (2)" width="90" x="514" y="300"> <process expanded="true"> <operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" name="Tokenize (2)"/> <connect from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Create Document" from_port="output" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Process Documents" to_port="documents 2"/> <connect from_op="Create Document (3)" from_port="output" to_op="Process Documents" to_port="documents 3"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <connect from_op="Process Documents" from_port="word list" to_op="Process Documents (2)" to_port="word list"/> <connect from_op="Create Document (4)" from_port="output" to_op="Process Documents (2)" to_port="documents 1"/> <connect from_op="Process Documents (2)" from_port="example set" to_port="result 3"/> <connect from_op="Process Documents (2)" from_port="word list" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
