<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="556" width="815"> <operator activated="true" class="read_excel" compatibility="5.2.001" expanded="true" height="60" name="Read Excel (2)" width="90" x="45" y="165"> <parameter key="excel_file" value="E:\Rapidminer\links_summary.xls"/> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="work_on_subset" compatibility="5.2.001" expanded="true" height="76" name="Work on Subset (3)" width="90" x="179" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="teaser"/> <process expanded="true"> <connect from_port="exampleSet" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <operator activated="true" class="work_on_subset" compatibility="5.2.001" expanded="true" height="76" name="Work on Subset" width="90" x="313" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="title"/> <process expanded="true" height="738" width="914"> <connect from_port="exampleSet" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <operator activated="true" class="work_on_subset" compatibility="5.2.001" expanded="true" height="76" name="Work on Subset (2)" width="90" x="447" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="time"/> <process expanded="true" height="738" width="914"> <connect from_port="exampleSet" to_port="example set"/> <portSpacing port="source_exampleSet" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> </operator> <connect from_op="Read Excel (2)" from_port="output" to_op="Work on Subset (3)" to_port="example set"/> <connect from_op="Work on Subset (3)" from_port="example set" to_op="Work on Subset" to_port="example set"/> <connect from_op="Work on Subset" from_port="example set" to_op="Work on Subset (2)" to_port="example set"/> <connect from_op="Work on Subset (2)" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
