I'm trying to make pdf reports with embedded plots, and I'm having trouble with the image width and height parameters. They seem to be at least inverse, the bigger the number, the smaller the plot! Here's some XML with three plots of data to show the point.
<process version="5.1.013">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.013" expanded="true" name="Process">
<process expanded="true" height="415" width="819">
<operator activated="true" class="generate_data" compatibility="5.1.013" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/>
<operator activated="true" class="generate_id" compatibility="5.1.013" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/>
<operator activated="true" class="reporting:generate_report" compatibility="5.1.000" expanded="true" height="76" name="Generate Report" width="90" x="313" y="30">
<parameter key="report_name" value="blob"/>
<parameter key="pdf_output_file" value="C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\My Documents\blob.pdf"/>
<parameter key="pdf_template_file" value="C:\RapidMiner_Vega\no file selected"/>
<parameter key="image_template_file" value="C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\My Documents\KnowledgeGrinders.com\comp006.gif"/>
<parameter key="image_alignment" value="1"/>
<parameter key="section_one_font" value="courier"/>
<parameter key="section_two_font" value="courier"/>
<parameter key="section_three_font" value="courier"/>
<parameter key="section_four_font" value="courier"/>
<parameter key="section_five_font" value="courier"/>
<parameter key="text_content_font" value="courier"/>
<operator activated="true" class="reporting:add_pagebreak" compatibility="5.1.000" expanded="true" height="76" name="Add Pagebreak" width="90" x="447" y="30"/>
<operator activated="true" class="reporting:report" compatibility="5.1.000" expanded="true" height="60" name="800x600" width="90" x="45" y="165">
<parameter key="report_item_header" value="800x600"/>
<parameter key="specified" value="true"/>
<parameter key="reportable_type" value="Data Table"/>
<parameter key="renderer_name" value="Plot View"/>
<list key="parameters">
<parameter key="plotter" value="Series Multiple"/>
<parameter key="scatter_axis_x_axis_log_scale" value="false"/>
<parameter key="scatter_axis_y_axis_log_scale" value="false"/>
<parameter key="scatter_jitter_amount" value="0"/>
<parameter key="scatter_rotate_labels" value="false"/>
<parameter key="scatter_multiple_axis_x_axis_log_scale" value="false"/>
<parameter key="scatter_multiple_jitter_amount" value="0"/>
<parameter key="scatter_multiple_rotate_labels" value="false"/>
<parameter key="scatter_matrix_jitter_amount" value="0"/>
<parameter key="bubble_axis_x_axis_log_scale" value="false"/>
<parameter key="bubble_axis_y_axis_log_scale" value="false"/>
<parameter key="bubble_rotate_labels" value="false"/>
<parameter key="parallel_rotate_labels" value="false"/>
<parameter key="parallel_local_normalization" value="false"/>
<parameter key="deviation_rotate_labels" value="false"/>
<parameter key="deviation_local_normalization" value="false"/>
<parameter key="series_rotate_labels" value="false"/>
<parameter key="series_multiple_axis_index_dimension" value="id"/>
<parameter key="series_multiple_plot_columns" value="att1,att2,att3"/>
<parameter key="series_multiple_rotate_labels" value="false"/>
<parameter key="som_jitter_amount" value="0"/>
<parameter key="block_axis_x_axis_log_scale" value="false"/>
<parameter key="block_axis_y_axis_log_scale" value="false"/>
<parameter key="block_jitter_amount" value="0"/>
<parameter key="block_rotate_labels" value="false"/>
<parameter key="pie_absolute_values" value="false"/>
<parameter key="pie_aggregation" value="none"/>
<parameter key="pie_use_distinct" value="false"/>
<parameter key="pie_explosion_amount" value="0"/>
<parameter key="pie_3d_absolute_values" value="false"/>
<parameter key="pie_3d_aggregation" value="none"/>
<parameter key="pie_3d_use_distinct" value="false"/>
<parameter key="ring_absolute_values" value="false"/>
<parameter key="ring_aggregation" value="none"/>
<parameter key="ring_use_distinct" value="false"/>
<parameter key="ring_explosion_amount" value="0"/>
<parameter key="bars_absolute_values" value="false"/>
<parameter key="bars_rotate_labels" value="false"/>
<parameter key="bars_aggregation" value="none"/>
<parameter key="bars_use_distinct" value="false"/>
<parameter key="bars_orientation" value="vertical"/>
<parameter key="bars_stacked_absolute_values" value="false"/>
<parameter key="bars_stacked_rotate_labels" value="false"/>
<parameter key="bars_stacked_aggregation" value="none"/>
<parameter key="bars_stacked_use_distinct" value="false"/>
<parameter key="bars_stacked_orientation" value="vertical"/>
<parameter key="pareto_rotate_labels" value="false"/>
<parameter key="pareto_sorting_direction" value="Descending Keys"/>
<parameter key="pareto_show_bar_labels" value="true"/>
<parameter key="pareto_show_cumulative_labels" value="false"/>
<parameter key="distribution_rotate_labels" value="false"/>
<parameter key="histogram_absolute_values" value="false"/>
<parameter key="histogram_rotate_labels" value="false"/>
<parameter key="histogram_log_scale" value="false"/>
<parameter key="histogram_number_of_bins" value="40"/>
<parameter key="histogram_opaqueness" value="100"/>
<parameter key="histogram_color_absolute_values" value="false"/>
<parameter key="histogram_color_rotate_labels" value="false"/>
<parameter key="histogram_color_log_scale" value="false"/>
<parameter key="histogram_color_number_of_bins" value="40"/>
<parameter key="histogram_color_opaqueness" value="100"/>
</list>
<operator activated="true" class="reporting:add_pagebreak" compatibility="5.1.000" expanded="true" height="76" name="Add Pagebreak (2)" width="90" x="179" y="165"/>
<operator activated="true" class="reporting:report" compatibility="5.1.000" expanded="true" height="60" name="8000x6000" width="90" x="313" y="165">
<parameter key="report_item_header" value="8000x6000"/>
</list>
<parameter key="image_width" value="8000"/>
<parameter key="image_height" value="6000"/>
<operator activated="true" class="reporting:add_pagebreak" compatibility="5.1.000" expanded="true" height="76" name="Add Pagebreak (3)" width="90" x="447" y="165"/>
<operator activated="true" class="reporting:report" compatibility="5.1.000" expanded="true" height="60" name="80x60" width="90" x="651" y="153">
<parameter key="report_item_header" value="80x60"/>
</list>
<parameter key="image_width" value="80"/>
<parameter key="image_height" value="60"/>
<connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Generate Report" to_port="through 1"/>
<connect from_op="Generate Report" from_port="through 1" to_op="Add Pagebreak" to_port="through 1"/>
<connect from_op="Add Pagebreak" from_port="through 1" to_op="800x600" to_port="reportable in"/>
<connect from_op="800x600" from_port="reportable out" to_op="Add Pagebreak (2)" to_port="through 1"/>
<connect from_op="Add Pagebreak (2)" from_port="through 1" to_op="8000x6000" to_port="reportable in"/>
<connect from_op="8000x6000" from_port="reportable out" to_op="Add Pagebreak (3)" to_port="through 1"/>
<connect from_op="Add Pagebreak (3)" from_port="through 1" to_op="80x60" to_port="reportable in"/>
<connect from_op="80x60" from_port="reportable out" to_port="result 1"/>
</process>
</process>
Has anyone experience of this extension, and in particular this problem?
PS The SVN Vega build properties are still pointing to 5.1, hence the odd version number.
