<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.013" expanded="true" name="Root"> <process expanded="true" height="584" width="915"> <operator activated="true" class="retrieve" compatibility="5.1.013" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../data/Labor-Negotiations"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.1.013" expanded="true" height="94" name="MissingValueReplenishment" width="90" x="180" y="30"> <list key="columns"/> </operator> <operator activated="true" class="x_validation" compatibility="5.1.013" expanded="true" height="112" name="XValidation" width="90" x="315" y="30"> <parameter key="number_of_validations" value="5"/> <process expanded="true" height="347" width="385"> <operator activated="true" class="k_nn" compatibility="5.1.013" expanded="true" height="76" name="NearestNeighbors" width="90" x="152" y="30"> <parameter key="k" value="3"/> </operator> <connect from_port="training" to_op="NearestNeighbors" to_port="training set"/> <connect from_op="NearestNeighbors" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="347" width="413"> <operator activated="true" class="apply_model" compatibility="5.1.013" expanded="true" height="76" name="ModelApplier" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="write_special" compatibility="5.1.013" expanded="true" height="60" name="Write Special Format" width="90" x="147" y="166"> <parameter key="example_set_file" value="C:\Documents and Settings\Administrator.KNOWLEDG-P6715Y\My Documents\out.dat"/> <parameter key="special_format" value="$d"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.1.013" expanded="true" height="76" name="ClassificationPerformance" width="90" x="246" y="30"> <parameter key="accuracy" value="false"/> <parameter key="classification_error" value="true"/> <list key="class_weights"/> </operator> <connect from_port="model" to_op="ModelApplier" to_port="model"/> <connect from_port="test set" to_op="ModelApplier" to_port="unlabelled data"/> <connect from_op="ModelApplier" from_port="labelled data" to_op="Write Special Format" to_port="input"/> <connect from_op="Write Special Format" from_port="through" to_op="ClassificationPerformance" to_port="labelled data"/> <connect from_op="ClassificationPerformance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="MissingValueReplenishment" to_port="example set input"/> <connect from_op="MissingValueReplenishment" from_port="example set output" to_op="XValidation" to_port="training"/> <connect from_op="XValidation" from_port="averagable 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
