problems with 'select by random' operator [SOLVED]
User: "sfmorais"
New Altair Community Member
Updated by Jocelyn
Hi!
I have the same problem than
http://rapid-i.com/rapidforum/index.php/topic,3708.msg13825.html#msg13825
but I didn´t understand the solution.
I have a example set with some atributes. I want select one randomly atribute (for example with 'select by random' operator), but each time that I run the process the selected attribute is always the same.
How can I workaround it ?  (if possible with a example)
Many thanks for the help
Best Regards,
Sérgio Morais
1 - 4 of 41
    User: "Marco_Boeck"
    that is because the local random seed is fixed by default to allow reproduction of results. You can change that by selecting the process, and change the "random seed" parameter to -1.
    That way, the random function will use the current system time, and you will get a more random selection of attributes.
    Marco
    User: "sfmorais"
    OP
    I tried solve the problem in two different ways:
    1) In my process, in 'select by random' operator I tried changed 'local random seed' to -1 but the value is converted to 1 automatically
    2) In Rapid Miner 'Tools -> Preferences' I changed 'rapidminer.general.randomseed' option to '-1' and apply, and the problem is the same.
    I still with same problem (the selected attribute is always the same)
    (if necessary I send the xml of my problem)
    Many Thanks in advance
    Regards
    User: "MariusHelf"
    Marco was referring to the random seed of the Process, not of the operator. Just click an empty space in the process pane to see the properties of the process itself. Set the random seed to -1. Additionally, disable "use local random seed" for the Select by Random operator.
    Best,
    Marius
    User: "sfmorais"
    OP
    Ok! now I understood. It works!
    Thanks
