<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.013"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.013" expanded="true" name="Process"> <process expanded="true" height="457" width="839"> <operator activated="true" class="generate_data" compatibility="5.1.013" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"/> <operator activated="true" class="loop_attributes" compatibility="5.1.013" expanded="true" height="60" name="Loop Attributes" width="90" x="183" y="73"> <process expanded="true" height="457" width="839"> <operator activated="true" class="set_macro" compatibility="5.1.013" expanded="true" height="76" name="Set Macro" width="90" x="179" y="75"> <parameter key="macro" value="%{MYMACRO}"/> <parameter key="value" value="%{loop_attribute}"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.1.013" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="368" y="21"> <parameter key="macro_name" value="%{MYMACRO}"/> </operator> <operator activated="true" class="log" compatibility="5.1.013" expanded="true" height="76" name="Log" width="90" x="514" y="18"> <list key="log"> <parameter key="MYMACRO" value="operator.Set Macro.value.macro_value"/> </list> </operator> <connect from_port="example set" to_op="Set Macro" to_port="through 1"/> <connect from_op="Set Macro" from_port="through 1" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="example set"/> <portSpacing port="source_example set" spacing="90"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
