<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.017"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.017" expanded="true" name="Process"> <process expanded="true" height="415" width="681"> <operator activated="true" class="read_database" compatibility="5.1.017" expanded="true" height="60" name="Read Database" width="90" x="45" y="30"> <parameter key="connection" value="forums"/> <parameter key="query" value="SELECT `id`, `topic`, `detail` FROM `forum_question`"/> <enumeration key="parameters"/> <parameter key="datamanagement" value="double_sparse_array"/> </operator> <operator activated="true" class="rename" compatibility="5.1.017" expanded="true" height="76" name="Rename" width="90" x="179" y="30"> <parameter key="old_name" value="id"/> <parameter key="new_name" value="thread_id"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.017" expanded="true" height="76" name="Set Role" width="90" x="313" y="30"> <parameter key="name" value="thread_id"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"> <parameter key="topic" value="regular"/> <parameter key="detail" value="regular"/> </list> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.1.004" expanded="true" height="60" name="Data to Documents" width="90" x="447" y="30"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.1.004" expanded="true" height="94" name="Process Documents" width="90" x="45" y="255"> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="2.0"/> <parameter key="prune_above_percent" value="94.0"/> <parameter key="prune_below_absolute" value="1"/> <parameter key="prune_above_absolute" value="195"/> <parameter key="prune_below_rank" value="1.0"/> <parameter key="prune_above_rank" value="99.0"/> <process expanded="true" height="415" width="567"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.004" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30"/> <operator activated="true" class="text:tokenize" compatibility="5.1.004" expanded="true" height="60" name="Tokenize" width="90" x="45" y="165"> <parameter key="mode" value="specify characters"/> <parameter key="characters" value=" '.:,;?!()[]{}/\ '"/> <parameter key="expression" value="[\s]"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="5.1.004" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="300"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.004" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="246" y="30"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.1.004" expanded="true" height="60" name="Filter Stopwords (Dictionary)" width="90" x="246" y="165"> <parameter key="file" value="C:\Users\admin2\Documents\NetBeansProjects\Forums\StopWords_Enhanced.txt"/> </operator> <operator activated="true" class="text:filter_by_length" compatibility="5.1.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="246" y="300"> <parameter key="min_chars" value="3"/> <parameter key="max_chars" value="999"/> </operator> <operator activated="true" class="text:filter_tokens_by_content" compatibility="5.1.004" expanded="true" height="60" name="Filter Tokens (by Content)" width="90" x="447" y="165"> <parameter key="condition" value="contains match"/> <parameter key="regular_expression" value="[a-zA-Z-]+"/> </operator> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.1.004" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="447" y="300"/> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/> <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Tokens (by Content)" to_port="document"/> <connect from_op="Filter Tokens (by Content)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="k_means" compatibility="5.1.017" expanded="true" height="76" name="Clustering" width="90" x="179" y="165"> <parameter key="k" value="12"/> <parameter key="max_runs" value="50"/> <parameter key="max_optimization_steps" value="500"/> </operator> <operator activated="true" class="extract_prototypes" compatibility="5.1.017" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="380" y="165"/> <operator activated="true" class="write_csv" compatibility="5.1.017" expanded="true" height="60" name="Write CSV" width="90" x="514" y="165"> <parameter key="csv_file" value="C:\Users\admin2\Documents\NetBeansProjects\Forums\cluster_centroids.csv"/> <parameter key="column_separator" value=","/> <parameter key="quote_nominal_values" value="false"/> <parameter key="format_date_attributes" value="false"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.017" expanded="true" height="76" name="Select Attributes" width="90" x="380" y="300"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|thread_id|cluster"/> </operator> <operator activated="true" class="write_database" compatibility="5.1.017" expanded="true" height="60" name="Write Database" width="90" x="581" y="300"> <parameter key="connection" value="forums"/> <parameter key="table_name" value="forum_question_clusters"/> <parameter key="overwrite_mode" value="overwrite"/> </operator> <connect from_op="Read Database" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Write CSV" to_port="input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Write Database" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.015" expanded="true" name="Process"> <process expanded="true" height="611" width="681"> <operator activated="true" class="read_database" compatibility="5.1.015" expanded="true" height="60" name="Read Database" width="90" x="45" y="30"> <parameter key="connection" value="forums"/> <parameter key="query" value="SELECT `id`, `topic`, `detail` FROM `forum_question`"/> <enumeration key="parameters"/> <parameter key="datamanagement" value="double_sparse_array"/> </operator> <operator activated="true" class="rename" compatibility="5.1.015" expanded="true" height="76" name="Rename" width="90" x="179" y="30"> <parameter key="old_name" value="id"/> <parameter key="new_name" value="thread_id"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.015" expanded="true" height="76" name="Set Role" width="90" x="313" y="30"> <parameter key="name" value="thread_id"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"> <parameter key="topic" value="regular"/> <parameter key="detail" value="regular"/> </list> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.1.004" expanded="true" height="60" name="Data to Documents" width="90" x="447" y="30"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.1.004" expanded="true" height="94" name="Process Documents" width="90" x="45" y="165"> <parameter key="prune_method" value="percentual"/> <parameter key="prunde_below_percent" value="2.0"/> <parameter key="prune_above_percent" value="94.0"/> <parameter key="prune_below_absolute" value="1"/> <parameter key="prune_above_absolute" value="195"/> <parameter key="prune_below_rank" value="1.0"/> <parameter key="prune_above_rank" value="99.0"/> <process expanded="true" height="415" width="567"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.004" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30"/> <operator activated="true" class="text:tokenize" compatibility="5.1.004" expanded="true" height="60" name="Tokenize" width="90" x="45" y="165"> <parameter key="mode" value="specify characters"/> <parameter key="characters" value=" '.:,;?!()[]{}/\ '"/> <parameter key="expression" value="[\s]"/> </operator> <operator activated="true" class="text:transform_cases" compatibility="5.1.004" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="300"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.004" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="246" y="30"/> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.1.004" expanded="true" height="60" name="Filter Stopwords (Dictionary)" width="90" x="246" y="165"> <parameter key="file" value="C:\Users\admin2\Documents\NetBeansProjects\Forums\StopWords_Enhanced.txt"/> </operator> <operator activated="true" class="text:filter_by_length" compatibility="5.1.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="246" y="300"> <parameter key="min_chars" value="3"/> <parameter key="max_chars" value="999"/> </operator> <operator activated="true" class="text:filter_tokens_by_content" compatibility="5.1.004" expanded="true" height="60" name="Filter Tokens (by Content)" width="90" x="447" y="165"> <parameter key="condition" value="contains match"/> <parameter key="regular_expression" value="[a-zA-Z-]+"/> </operator> <operator activated="true" class="text:generate_n_grams_terms" compatibility="5.1.004" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="447" y="300"/> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/> <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Tokens (by Content)" to_port="document"/> <connect from_op="Filter Tokens (by Content)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="handle_exception" compatibility="5.1.015" expanded="true" height="76" name="Handle Exception" width="90" x="112" y="300"> <process expanded="true" height="633" width="346"> <operator activated="true" class="rename" compatibility="5.1.015" expanded="true" height="76" name="Rename (2)" width="90" x="112" y="30"> <parameter key="old_name" value="cluster"/> <parameter key="new_name" value="_cluster_"/> <list key="rename_additional_attributes"/> </operator> <connect from_port="in 1" to_op="Rename (2)" to_port="example set input"/> <connect from_op="Rename (2)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> <process expanded="true" height="633" width="346"> <connect from_port="in 1" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <operator activated="true" class="k_means" compatibility="5.1.015" expanded="true" height="76" name="Clustering" width="90" x="246" y="300"> <parameter key="k" value="12"/> <parameter key="max_runs" value="50"/> <parameter key="max_optimization_steps" value="500"/> </operator> <operator activated="true" class="extract_prototypes" compatibility="5.1.015" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="447" y="165"/> <operator activated="true" class="write_csv" compatibility="5.1.015" expanded="true" height="60" name="Write CSV" width="90" x="581" y="165"> <parameter key="csv_file" value="C:\Users\admin2\Documents\NetBeansProjects\Forums\cluster_centroids.csv"/> <parameter key="column_separator" value=","/> <parameter key="quote_nominal_values" value="false"/> <parameter key="format_date_attributes" value="false"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.015" expanded="true" height="76" name="Select Attributes" width="90" x="447" y="345"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="|thread_id|cluster"/> </operator> <operator activated="true" class="write_database" compatibility="5.1.015" expanded="true" height="60" name="Write Database" width="90" x="581" y="345"> <parameter key="connection" value="forums"/> <parameter key="table_name" value="forum_question_clusters"/> <parameter key="overwrite_mode" value="overwrite"/> </operator> <connect from_op="Read Database" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_op="Handle Exception" to_port="in 1"/> <connect from_op="Handle Exception" from_port="out 1" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Write CSV" to_port="input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Write Database" to_port="input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
