Hei..
I`ve try the APi, but i still dont know how to see the output on my process..
here the console says:
Jan 17, 2012 9:53:17 AM com.rapidminer.tools.WrapperLoggingHandler log
INFO: No filename given for result file, using stdout for logging results!
Jan 17, 2012 9:53:17 AM com.rapidminer.Process run
INFO: Process starts
Jan 17, 2012 9:53:18 AM com.rapidminer.Process run
INFO: Process finished successfully after 0 s
Jan 17, 2012 9:53:18 AM com.rapidminer.tools.WrapperLoggingHandler log
and here is the code
import com.rapidminer.repository.RepositoryLocation;
import com.rapidminer.repository.RepositoryManager;
import com.rapidminer.tools.OperatorService;
import com.rapidminer.Process;
import com.rapidminer.*;
import com.rapidminer.RapidMiner.ExecutionMode;
import com.rapidminer.example.Attribute;
import com.rapidminer.example.Example;
import com.rapidminer.operator.IOContainer;
import com.rapidminer.operator.IOObject;
//import com.rapidminer.operator.ExecutionUnit;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.ExecutionMode.*;
import com.rapidminer.example.ExampleSet;
import com.rapidminer.gui.*;
import java.io.*;
//import com.rapidminer.operator.OperatorException;
//import com.rapidminer.operator.IOContainer;
//import java.io.IOException;
import java.io.File;
import java.util.Iterator;
public class Main {
static String line;
static String x="C:\\Documents and Settings\\user\\My Documents\\RapidMiner\\model1.rmp";
private static String readFileAsString(String filePath)
throws java.io.IOException{
StringBuffer fileData = new StringBuffer(1000);
BufferedReader reader = new BufferedReader(
new FileReader(filePath));
char[] buf = new char[1024];
int numRead=0;
while((numRead=reader.read(buf)) != -1){
String readData = String.valueOf(buf, 0, numRead);
fileData.append(readData);
reader.close();
return fileData.toString();
public static void main(String[] argv) throws Exception {
// MUST BE INVOKED BEFORE ANYTHING ELSE !!!
RapidMiner.setExecutionMode(ExecutionMode.COMMAND_LINE);
RapidMiner.init();
Process process=new Process(readFileAsString(x));
IOContainer ioResult = process.run();
if (ioResult.getElementAt(0) instanceof ExampleSet) {
ExampleSet resultSet = (ExampleSet)ioResult.getElementAt(0);
RepositoryLocation resloc = new RepositoryLocation("//MyRepository/contohg");
RepositoryManager.getInstance(null).store(resultSet, resloc, null);
process.run();
so what should i do next, if i want to see the output?
