<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.015"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.015" expanded="true" name="Process"> <process expanded="true" height="145" width="279"> <operator activated="true" class="loop" compatibility="5.1.015" expanded="true" height="76" name="Loop" width="90" x="179" y="30"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="10"/> <process expanded="true" height="634" width="743"> <operator activated="true" class="retrieve" compatibility="5.1.015" expanded="true" height="60" name="Retrieve" width="90" x="112" y="30"> <parameter key="repository_entry" value="some_name_%{iteration}"/> </operator> <connect from_op="Retrieve" from_port="output" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Loop" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
