"R extension"
NJS
I got problem installing R extension in RM.
I use R 2.14 64bits and RM 5.1 64bits.
Window7
Variables set:
JAVA_HOME: C:\Program Files\Java\jre6\bin
R_HOME: C:\Program Files\R\R-2.14.0
When starting RM, I got the R extension instructions but it never worked (failed to load R library.
Somebody could help?
Thanks a lot,
Nathalie
Extensions
R
MariusHelf
Hi Nathalie,
do you see any error messages? Please check also the log view in RapidMiner. If you find any error messages, please post them here.
Kind regards,
Marius
haddock
Hi there Natalie,
I see you have 64 bit Java, if your R installation is not also 64 bit then you will get a system load error. I'm writing a Cuda plugin which needs to be 64 bit, and if my Java isn't also 64 bit I get this sort of error.
Just a thought.
NJS
Thanks for your answer. I got R 64bits as well as RM 64bits.
Running the RM console, I got the arror message below. Pretty long message but maybe it could help to get the problem solved...
Thanks a lot for your help,
Nathalie
C:\Users\Nathalie\AppData\Local\Temp\RtmpWydhV8\downloaded_packages
[1] "C:/Users/Nathalie/Documents/R/win-library/2.14"
[2] "C:/Program Files/R/R-2.14.0/library"
RAPIDMINER_HOME is not set. Trying the directory 'C:\Program Files\Rapid-I\Rapid
Miner5\scripts\..'...
Using local jre: C:\Program Files\Rapid-I\RapidMiner5\scripts\..\jre\bin\java.ex
e...
Starting RapidMiner from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..' using
classes from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..\lib\rapidminer.ja
r'...
7 dÚc. 2011 03:55:03 com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'.
7 dÚc. 2011 03:55:03 com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform WIN64
7 dÚc. 2011 03:55:05 com.rapid_i.Launcher ensureRapidMinerHomeSet
7 dÚc. 2011 03:55:05 com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
7 dÚc. 2011 03:55:05 com.rapidminer.PluginInitR initPlugin
INFO: Trying to load R Library...
7 dÚc. 2011 03:55:05 org.rosuda.JRI.Rengine <clinit>
INFO: Creating Connection to R...
7 dÚc. 2011 03:55:05 org.rosuda.JRI.Rengine loadLibrary
INFO: Trying to loaded R library from C:\Users\Nathalie\Documents\R\win-library\
2.14\rJava\jri\x64\jri.dll
INFO: Engine ID: class org.rosuda.JRI.Rengine ClassLoader:PluginClassLoader ([fi
le:/C:/Users/Nathalie/.RapidMiner5/managed/rmx_r-5.1.4.jar])
7 dÚc. 2011 03:55:05 com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: r.could_not_load_native_lib
7 dÚc. 2011 03:55:05 com.rapidminer.PluginInitR loadNativeLibrary
SEVERE: r.could_not_load_native_lib
java.lang.UnsatisfiedLinkError: C:\Users\Nathalie\Documents\R\win-library\2.14\r
Java\jri\x64\jri.dll: Can't find dependent libraries
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at org.rosuda.JRI.Rengine.loadLibrary(Rengine.java:109)
at org.rosuda.JRI.Rengine.loadLibrary(Rengine.java:122)
at com.rapidminer.PluginInitR.loadNativeLibrary(PluginInitR.java:163)
at com.rapidminer.PluginInitR.initPlugin(PluginInitR.java:88)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.rapidminer.tools.plugin.Plugin.callInitMethod(Plugin.java:798)
at com.rapidminer.tools.plugin.Plugin.callPluginInitMethods(Plugin.java:
776)
at com.rapidminer.tools.plugin.Plugin.initPlugins(Plugin.java:762)
at com.rapidminer.tools.plugin.Plugin.initAll(Plugin.java:877)
at com.rapidminer.RapidMiner.init(RapidMiner.java:456)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:221)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:505)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:488)
at com.rapid_i.Launcher.main(Launcher.java:334)
7 dÚc. 2011 03:55:05 org.rosuda.JRI.Rengine isJriLoaded
WARNING: Access on Rengine but initialization failed! ID:1884473012
WARNING: Loading library on the fly...
WARNING: Error during loading library on the fly!
at org.rosuda.JRI.Rengine.isJriLoaded(Rengine.java:134)
at com.rapidminer.PluginInitR.initPlugin(PluginInitR.java:89)
776)
SEVERE: Failed to load R library!
7 dÚc. 2011 03:55:09 com.rapidminer.parameter.ParameterTypePassword decryptPassw
ord
WARNING: Password in XML file looks like unencrypted plain text.
[Fatal Error] :1:1: Content is not allowed in prolog.
7 dÚc. 2011 03:55:18 com.rapidminer.operator.r.ROperatorFactory readROperatorFra
gments
WARNING: Could not read R fragments from 'file:/C:/Program%20Files/Rapid-I/Rapid
Miner5/', error: Content is not allowed in prolog.
org.xml.sax.SAXParseException: Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(Unknown So
urce)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(Unk
nown Source)
at javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
at com.rapidminer.io.process.XMLTools.parse(XMLTools.java:175)
at com.rapidminer.operator.r.ROperatorFactory.readROperatorFragments(ROp
eratorFactory.java:166)
at com.rapidminer.operator.r.ROperatorFactory.<init>(ROperatorFactory.ja
va:129)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Sou
rce)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.j
ava:294)
ava:232)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorServic
e.java:206)
at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:471)
at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.
java:725)
at com.rapidminer.tools.OperatorService.init(OperatorService.java:167)
at com.rapidminer.RapidMiner.init(RapidMiner.java:465)
7 dÚc. 2011 03:55:18 com.rapidminer.operator.r.ROperatorFactory <init>
WARNING: Could not read documentation of user defined R operators from .
java.io.IOException: Malformed XML operator help bundle: org.xml.sax.SAXParseExc
at com.rapidminer.tools.documentation.XMLOperatorDocBundle.<init>(XMLOpe
ratorDocBundle.java:119)
va:150)
rce)
ava:294)
ava:232)
e.java:206)
java:725)
Caused by: org.xml.sax.SAXParseException: Content is not allowed in prolog.
urce)
nown Source)
ratorDocBundle.java:117)
... 22 more
7 dÚc. 2011 03:55:18 com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for 'ODBC Bridge (e.g. Access)'
7 dÚc. 2011 03:55:18 com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is
not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver
is not installed.
7 dÚc. 2011 03:55:24 com.rapidminer.tools.I18N getMessage
WARNING: Missing I18N key: gui.action.workspace_Nath.label
7 dÚc. 2011 03:55:24 org.rosuda.JRI.Rengine isJriLoaded
7 dÚc. 2011 03:55:24 org.rosuda.JRI.Rengine loadLibrary
at com.rapidminer.PluginInitR.initGui(PluginInitR.java:100)
776)
at com.rapidminer.tools.plugin.Plugin.initPluginGuis(Plugin.java:754)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:248)
haddock
Hi there,
Looking at the error message, it looks like a path problem. Have you checked this out?
http://rapid-i.com/rapidforum/index.php/topic,2612.msg10451.html#msg10451
