Hi all,
I use rapidminer 5.1.011 to design a text classification process, it's working fine in GUI. Now i'm trying to automate this process in java program. I wrote a simple Java program and when i run it i got the following errors:
com.rapidminer.operator.UserError: Could not read file '/home/some_user/wordlist': java.io.IOException: Cannot read from XML stream, wrong format: WordList : WordList. at com.rapidminer.operator.io.IOObjectReader.read(IOObjectReader.java:100) at com.rapidminer.operator.io.AbstractReader.doWork(AbstractReader.java:123) at com.rapidminer.operator.Operator.execute(Operator.java:833) at com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51) at com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:709) at com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:369) at com.rapidminer.operator.Operator.execute(Operator.java:833) at com.rapidminer.Process.run(Process.java:920) at com.rapidminer.Process.run(Process.java:843) at com.rapidminer.Process.run(Process.java:802) at com.rapidminer.Process.run(Process.java:797) at com.rapidminer.Process.run(Process.java:787) at ProcessCreator.main(ProcessCreator.java:18) Caused by: java.io.IOException: Cannot read from XML stream, wrong format: WordList : WordList at com.rapidminer.tools.XMLSerialization.fromXML(XMLSerialization.java:141) ...
Process config XML:
<process version="5.1.011">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process">
<process expanded="true" height="695" width="989">
<operator activated="true" class="read" compatibility="5.1.011" expanded="true" height="60" name="Read" width="90" x="45" y="210">
<parameter key="object_file" value="/home/some_user/wordlist"/>
<parameter key="io_object" value="WordList"/>
<operator activated="true" class="text:process_document_from_file" compatibility="5.1.003" expanded="true" height="76" name="Process Documents from Files" width="90" x="179" y="210">
<list key="text_directories">
<parameter key="porn" value="/home/some_user/test_data/porn"/>
</list>
<operator activated="true" class="web:extract_html_text_content" compatibility="5.1.004" expanded="true" height="60" name="Extract Content" width="90" x="45" y="30"/>
<operator activated="true" class="text:transform_cases" compatibility="5.1.003" expanded="true" height="60" name="Transform Cases" width="90" x="180" y="30"/>
<operator activated="true" class="text:tokenize" compatibility="5.1.003" expanded="true" height="60" name="Tokenize" width="90" x="315" y="30"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.003" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="450" y="30"/>
<operator activated="true" class="text:stem_snowball" compatibility="5.1.003" expanded="true" height="60" name="Stem (Snowball)" width="90" x="585" y="30"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.1.003" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="787" y="30">
<parameter key="min_chars" value="2"/>
<parameter key="max_chars" value="99"/>
<connect from_port="document" to_op="Extract Content" to_port="document"/>
<connect from_op="Extract Content" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
<connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="select_attributes" compatibility="5.1.011" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="210">
<parameter key="attribute_filter_type" value="no_missing_values"/>
<parameter key="attributes" value="|label|text"/>
<operator activated="true" class="read_model" compatibility="5.1.011" expanded="true" height="60" name="Read Model" width="90" x="380" y="30">
<parameter key="model_file" value="/home/some_user/svm_model"/>
<operator activated="true" class="set_role" compatibility="5.1.011" expanded="true" height="76" name="Set Role" width="90" x="447" y="210">
<parameter key="name" value="label"/>
<operator activated="true" class="apply_model" compatibility="5.1.011" expanded="true" height="76" name="Apply Model" width="90" x="581" y="120">
<operator activated="true" class="performance_classification" compatibility="5.1.011" expanded="true" height="76" name="Performance" width="90" x="715" y="120">
<list key="class_weights"/>
<connect from_op="Read" from_port="output" to_op="Process Documents from Files" to_port="word list"/>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Read Model" from_port="output" to_op="Apply Model" to_port="model"/>
<connect from_op="Set Role" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="result 1"/>
</process>
</process>
Java code:
import com.rapidminer.tools.OperatorService;
import com.rapidminer.RapidMiner;
import com.rapidminer.Process;
import java.io.*;
import java.io.IOException;
public class ProcessCreator {
public static void main(String[] argv) {
try {
RapidMiner.setExecutionMode(com.rapidminer.RapidMiner.ExecutionMode.EMBEDDED_WITHOUT_UI);
RapidMiner.init();
Process process = new Process(new File(argv[0]));
// perform process
process.run();
} catch (Exception e) { e.printStackTrace(); }
Appreciated ur help!
