Marius wrote:Hi, it just means that you are using an absolute path. If your process is stored in the same repository as your data, you should use relative paths. The easiest way to do this is to reselect the data entry by clicking the button in the operator parameters, and check "Resolove relative to..." in the dialog.If your processes and data are stored in different repositories (which we do not recommend) you can savely ignore the warning.Regards,Marius
