"Driver for connecting to Oracle Database"
Anki
Hi Community,
I am using RapidMiner-5 64 bit, Windows server 2003 (64 bit) as OS, JDK 1.6 java version, Oracle 11g for Database.
My problem is I am unable to connect to Database with RM. I tried with ojdbc14.jar and ojdbc6.jar, but no use.
Please give me solution, which drivers I have to use.
Thank you
Yours
Anki
Databases
Oracle
fischer
Oracle changed the name of the driver class. You can go to Tools -> Manage Database Drivers and create a new Oracle Driver with class name "oracle.jdbc.OracleDriver" (as opposed to "oracle.jdbc.driver.OracleDriver"). That will probably solve the problem.
Best,
Simon
Anki
Hi Simon,
Thank you for your help. I did changes, but still not solved
Tools-Manage Drivers - Add oracle - and parameters as
port : 1521
Browsed for ojdbc14.jar and ojdbc6.jar
Class: oracle.jdbc.OracleDriver
But still not connected.
Please correct me if I did wrong in the procedure.
Thank you
Yours
Anki
Anki
Hi Simon and all
YES, above method is working fine. Thank you.
But while I am establishing, an error is coming as
listener refused the connection with the following error ora-12505
What could be the reason? any solution
Thank you
Yours
Anki
colo
Hi Anki,
since this issue is named, there should be some material about it.
Maybe some of these will be helpful:
http://lmgtfy.com/?q=oracle+ora-12505
Regards
Matthias
Anki
Hi Matthias,
The Problem solved. Thank you.
Yours
Anki
marcopo
Hello Community,
I am a newbie in Rapidminer (5.2.008) and I am trying to establish a connection to an oracle database 11g. I was faced with the same error and I handled it in the way it was shown in the post. In the end I got the same ORA-12505 error. I tried to solve it in the way it was suggested but without suggest. What should I do?
Please help me.....
My listner.ora
# listener.ora Netw
ork Configuration File: C:\app\pospiech\product\11.2.0\dbhome_1\network\admin\listener.ora
# Generated by Oracle configuration tools.
SID_LIST_LISTENER =
(SID_LIST =
(SID_DESC =
(SID_NAME = CLRExtProc)
(ORACLE_HOME = C:\app\product\11.2.0\dbhome_1)
(PROGRAM = extproc)
(ENVS = "EXTPROC_DLLS=ONLY:C:\app\product\11.2.0\dbhome_1\bin\oraclr11.dll")
LISTENER =
(DESCRIPTION_LIST =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521))
(ADDRESS = (PROTOCOL = TCP)(HOST = localhost)(PORT = 1521))
ADR_BASE_LISTENER = C:\app
Best Regards
Marco
