Data1Record2Information3
<Document><B>Data<A>1</A></B><B>Record<A>2</A></B><B>Information<A>3</A></B></Document>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.011"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process"> <process expanded="true" height="657" width="748"> <operator activated="true" class="read_csv" compatibility="5.1.011" expanded="true" height="60" name="Read CSV" width="90" x="45" y="75"> <parameter key="csv_file" value="C:\Users\jedward\Desktop\test.csv"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <parameter key="encoding" value="UTF-8"/> <list key="data_set_meta_data_information"> <parameter key="0" value="att1.true.polynominal.attribute"/> </list> </operator> <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="Generate ID" width="90" x="45" y="210"/> <operator activated="true" class="generate_attributes" compatibility="5.1.011" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="165"> <list key="function_descriptions"> <parameter key="XML" value="if((ceil((id/2))==(id/2)),concat("<A>",att1,"</A></B>"),concat("<B>",att1,""))"/> </list> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.011" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="XML"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.1.011" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="246" y="30"> <list key="attribute_values"> <parameter key="XML" value=""<Document>""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.1.011" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="380" y="390"> <list key="attribute_values"> <parameter key="XML" value=""</Document>""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.1.011" expanded="true" height="112" name="Append" width="90" x="447" y="75"/> <operator activated="true" class="write_special" compatibility="5.1.011" expanded="true" height="60" name="Write Special Format" width="90" x="581" y="120"> <parameter key="example_set_file" value="C:\Users\jheath\Desktop\testXML.xml"/> <parameter key="special_format" value="$a"/> <parameter key="add_line_separator" value="false"/> <parameter key="quote_nominal_values" value="false"/> <parameter key="encoding" value="UTF-8"/> </operator> <operator activated="true" class="subprocess" compatibility="5.1.011" expanded="true" height="76" name="Subprocess" width="90" x="581" y="345"> <process expanded="true" height="568" width="488"> <operator activated="true" class="read_xml" compatibility="5.1.011" expanded="true" height="60" name="Read XML" width="90" x="190" y="218"> <parameter key="file" value="C:\Users\jedward\Desktop\testXML.xml"/> <parameter key="xpath_for_examples" value="//Document/B"/> <enumeration key="xpaths_for_attributes"> <parameter key="xpath_for_attribute" value="text()"/> <parameter key="xpath_for_attribute" value="A[1]/text()"/> </enumeration> <list key="namespaces"/> <parameter key="use_default_namespace" value="false"/> <parameter key="parse_numbers" value="false"/> <list key="annotations"/> <list key="data_set_meta_data_information"> <parameter key="0" value="DataHeader.true.polynominal.attribute"/> <parameter key="1" value="ID.true.integer.id"/> </list> </operator> <connect from_op="Read XML" from_port="output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Read CSV" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Append" to_port="example set 2"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 3"/> <connect from_op="Append" from_port="merged set" to_op="Write Special Format" to_port="input"/> <connect from_op="Write Special Format" from_port="through" to_op="Subprocess" to_port="in 1"/> <connect from_op="Subprocess" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process"> <process expanded="true" height="566" width="547"> <operator activated="true" class="read_excel" compatibility="5.1.006" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75"> <parameter key="excel_file" value="C:\Users\userDesktop\read\dok.xls"/> <parameter key="imported_cell_range" value="A1:A100"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <list key="data_set_meta_data_information"> <parameter key="0" value="content.true.text.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_sparse_array"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="5.1.001" expanded="true" height="60" name="Data to Documents" width="90" x="200" y="183"> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" compatibility="5.1.001" expanded="true" height="94" name="Process Documents" width="90" x="380" y="165"> <parameter key="keep_text" value="true"/> <process expanded="true" height="580" width="593"> <connect from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Read Excel" from_port="output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_port="result 1"/> <connect from_op="Process Documents" from_port="word list" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
