How can we obtain the global stiffness matrix of a component in Simlab?
Best regards and thank you
in SL, as far as I know, the command is not there yet, but you could add it manually as 'Text Data' to the solver deck, ath the input/ouput section.
OUTPUT,MATRIX
https://2021.help.altair.com/2021/hwsolvers/os/topics/solvers/os/output_io_r.htm
Thank you very much, it worked I think. The problem is that the file is too large (45 Gb), maybe a better approach is to output only specific nodes? Is that possible?
There are a few options in the documentation.
But indeed, it might get very large.
Try requesting it in Sparse format, to eliminate the zeros.
Maybe it would reduce it.
