Target ShufflingShuffles the labels of the input example set. Be sure to define the label and id attribute names.sort_up_down.png<?xml version="1.0" encoding="UTF-8" standalone="no"?><!-- This achieves "target shuffling". I don't know if it is the most elegant way. It does so by: 1) multiplying the example set 2) in one copy: 2.1) leave only the label 2.2) shuffle examples (which are only hte labels) 3) in the other: 3.1) remove the label 3.2) rename the id to old_id 3.3) make it a regular attribute 4) add a "fake" id column to both copies 5) join copies 6) clean up: 6.1) remove fake id 6.2) rename old_id to id 6.3) make it an id attribute Assumptions: 1) Input ExampleSet has a label attribute 2) Input ExampleSet has an id attribute Instructions: 1) set up name of label attribute 2) set up name of id attribute Created by Amnon Khen <amnon.is@gmail.com>--><operator activated="true" class="subprocess" compatibility="5.1.011" expanded="true" height="76" name="Target Shuffling" width="90" x="179" y="300"> <description>This achieves "target shuffling".I don't know if it is the most elegant way.It does so by:1) multiplying the example set2) in one copy:2.1) leave only the label2.2) shuffle examples (which are only hte labels)3) in the other:3.1) remove the label3.2) rename the id to old_id 3.3) make it a regular attribute4) add a "fake" id column to both copies5) join copies6) clean up:6.1) remove fake id6.2) rename old_id to id6.3) make it an id attributeAssumptions:1) Input ExampleSet has a label attribute2) Input ExampleSet has an id attributeInstructions:1) set up name of label attribute2) set up name of id attribute</description> <parameter key="parallelize_nested_chain" value="false"/> <process expanded="true" height="644" width="1054"> <operator activated="true" class="print_to_console" compatibility="5.1.011" expanded="true" height="76" name="Print to Console (7)" width="90" x="45" y="30"> <parameter key="log_value" value="shuffling labels"/> </operator> <operator activated="true" class="set_macro" compatibility="5.1.011" expanded="true" height="76" name="def. label attr. name" width="90" x="179" y="30"> <parameter key="macro" value="label_attribute_name"/> <parameter key="value" value="Class"/> </operator> <operator activated="true" class="set_macro" compatibility="5.1.011" expanded="true" height="76" name="def. id attr." width="90" x="315" y="30"> <parameter key="macro" value="id_attribute_name"/> <parameter key="value" value="id"/> </operator> <operator activated="true" class="print_to_console" compatibility="5.1.011" expanded="true" height="76" name="log label attr." width="90" x="447" y="30"> <parameter key="log_value" value="label attribute: %{label_attribute_name}"/> </operator> <operator activated="true" class="print_to_console" compatibility="5.1.011" expanded="true" height="76" name="log id attr." width="90" x="585" y="30"> <parameter key="log_value" value="id attribute: %{id_attribute_name}"/> </operator> <operator activated="true" class="multiply" compatibility="5.1.011" expanded="true" height="94" name="Multiply" width="90" x="45" y="210"/> <operator activated="true" class="set_role" compatibility="5.1.011" expanded="true" height="76" name="id -> regular" width="90" x="112" y="345"> <parameter key="name" value="%{id_attribute_name}"/> <parameter key="target_role" value="regular"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="rename" compatibility="5.1.011" expanded="true" height="76" name="rename id -> old_id" width="90" x="246" y="345"> <parameter key="old_name" value="%{id_attribute_name}"/> <parameter key="new_name" value="old_id"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.011" expanded="true" height="76" name="remove label" width="90" x="380" y="345"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{label_attribute_name}"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.011" expanded="true" height="76" name="leave only labels" width="90" x="179" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="%{label_attribute_name}"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="shuffle" compatibility="5.1.011" expanded="true" height="76" name="Shuffle labels" width="90" x="313" y="210"> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="generate fake id for shuffled labels" width="90" x="447" y="210"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="generate_id" compatibility="5.1.011" expanded="true" height="76" name="generate fake id for example set" width="90" x="514" y="345"> <parameter key="create_nominal_ids" value="false"/> <parameter key="offset" value="0"/> </operator> <operator activated="true" class="join" compatibility="5.1.011" expanded="true" height="76" name="Join" width="90" x="648" y="300"> <parameter key="remove_double_attributes" value="true"/> <parameter key="join_type" value="inner"/> <parameter key="use_id_attribute_as_key" value="true"/> <list key="key_attributes"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.011" expanded="true" height="76" name="remove fake id" width="90" x="648" y="480"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="rename" compatibility="5.1.011" expanded="true" height="76" name="rename old_id -> id" width="90" x="782" y="480"> <parameter key="old_name" value="old_id"/> <parameter key="new_name" value="%{id_attribute_name}"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.011" expanded="true" height="76" name="Set Role" width="90" x="916" y="480"> <parameter key="name" value="%{id_attribute_name}"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <connect from_port="in 1" to_op="Print to Console (7)" to_port="through 1"/> <connect from_op="Print to Console (7)" from_port="through 1" to_op="def. label attr. name" to_port="through 1"/> <connect from_op="def. label attr. name" from_port="through 1" to_op="def. id attr." to_port="through 1"/> <connect from_op="def. id attr." from_port="through 1" to_op="log label attr." to_port="through 1"/> <connect from_op="log label attr." from_port="through 1" to_op="log id attr." to_port="through 1"/> <connect from_op="log id attr." from_port="through 1" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="leave only labels" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="id -> regular" to_port="example set input"/> <connect from_op="id -> regular" from_port="example set output" to_op="rename id -> old_id" to_port="example set input"/> <connect from_op="rename id -> old_id" from_port="example set output" to_op="remove label" to_port="example set input"/> <connect from_op="remove label" from_port="example set output" to_op="generate fake id for example set" to_port="example set input"/> <connect from_op="leave only labels" from_port="example set output" to_op="Shuffle labels" to_port="example set input"/> <connect from_op="Shuffle labels" from_port="example set output" to_op="generate fake id for shuffled labels" to_port="example set input"/> <connect from_op="generate fake id for shuffled labels" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="generate fake id for example set" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Join" from_port="join" to_op="remove fake id" to_port="example set input"/> <connect from_op="remove fake id" from_port="example set output" to_op="rename old_id -> id" to_port="example set input"/> <connect from_op="rename old_id -> id" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="432"/> <portSpacing port="sink_out 2" spacing="0"/> </process></operator>
