<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output> <location>result</location> </output> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="460" width="681"> <operator activated="true" class="read_csv" compatibility="5.1.008" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30"> <parameter key="csv_file" value="C:\RapidM projekty\pedotransferky\data\tren_a_valid.txt"/> <parameter key="column_separators" value="	"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1250"/> <list key="data_set_meta_data_information"> <parameter key="0" value="I.true.real.attribute"/> <parameter key="1" value="II.true.real.attribute"/> <parameter key="2" value="III.true.real.attribute"/> <parameter key="3" value="IV.true.real.attribute"/> <parameter key="4" value="ro.true.real.attribute"/> <parameter key="5" value="f2\.50.false.real.label"/> <parameter key="6" value="f56\.00.false.real.label"/> <parameter key="7" value="f209\.00.true.real.label"/> <parameter key="8" value="f558\.00.false.real.label"/> <parameter key="9" value="f976\.00.false.real.label"/> <parameter key="10" value="f3060\.00.false.real.label"/> <parameter key="11" value="f15300\.00.false.real.label"/> </list> </operator> <operator activated="true" class="normalize" compatibility="5.1.008" expanded="true" height="94" name="Normalize" width="90" x="179" y="30"> <parameter key="method" value="range transformation"/> </operator> <operator activated="true" class="multiply" compatibility="5.1.008" expanded="true" height="94" name="Multiply" width="90" x="313" y="30"/> <operator activated="true" class="optimize_parameters_grid" compatibility="5.1.008" expanded="true" height="94" name="OP" width="90" x="447" y="30"> <list key="parameters"> <parameter key="SVM.C" value="[1;601;200;linear]"/> <parameter key="SVM.gamma" value="[0.1;1;20;linear]"/> </list> <process expanded="true" height="421" width="653"> <operator activated="true" class="x_validation" compatibility="5.1.008" expanded="true" height="112" name="Validation" width="90" x="112" y="165"> <parameter key="number_of_validations" value="5"/> <parameter key="sampling_type" value="linear sampling"/> <process expanded="true" height="441" width="278"> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.1.008" expanded="true" height="76" name="SVM" width="90" x="94" y="30"> <parameter key="svm_type" value="epsilon-SVR"/> <parameter key="degree" value="2"/> <parameter key="gamma" value="1.0"/> <parameter key="coef0" value="50.0"/> <parameter key="C" value="601.0"/> <list key="class_weights"/> </operator> <connect from_port="training" to_op="SVM" to_port="training set"/> <connect from_op="SVM" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="441" width="278"> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.1.008" expanded="true" height="76" name="Performance (2)" width="90" x="161" y="30"> <parameter key="main_criterion" value="correlation"/> <parameter key="root_mean_squared_error" value="false"/> <parameter key="correlation" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <operator activated="true" class="log" compatibility="5.1.008" expanded="true" height="76" name="Log" width="90" x="313" y="120"> <parameter key="filename" value="C:\Documents and Settings\Milan\My Documents\pokus.log"/> <list key="log"> <parameter key="gamma" value="operator.SVM.parameter.gamma"/> <parameter key="C" value="operator.SVM.parameter.C"/> <parameter key="epsilon - p" value="operator.SVM.parameter.p"/> <parameter key="epsilon-e" value="operator.SVM.parameter.epsilon"/> <parameter key="correl" value="operator.Performance (2).value.correlation"/> </list> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <operator activated="true" class="set_parameters" compatibility="5.1.008" expanded="true" height="60" name="Set Parameters" width="90" x="581" y="30"> <list key="name_map"> <parameter key="SVM" value="SVM2"/> </list> </operator> <operator activated="true" class="read_csv" compatibility="5.1.008" expanded="true" height="60" name="Read CSV (3)" width="90" x="112" y="345"> <parameter key="csv_file" value="C:\RapidM projekty\pedotransferky\data\test12345.txt"/> <parameter key="column_separators" value="	"/> <parameter key="first_row_as_names" value="false"/> <list key="annotations"> <parameter key="0" value="Name"/> </list> <parameter key="encoding" value="windows-1250"/> <list key="data_set_meta_data_information"> <parameter key="0" value="I.true.real.attribute"/> <parameter key="1" value="II.true.real.attribute"/> <parameter key="2" value="III.true.real.attribute"/> <parameter key="3" value="IV.true.real.attribute"/> <parameter key="4" value="ro.true.real.attribute"/> <parameter key="5" value="f2\.50.false.real.label"/> <parameter key="6" value="f56\.00.false.real.label"/> <parameter key="7" value="f209\.00.true.real.label"/> <parameter key="8" value="f558\.00.false.real.label"/> <parameter key="9" value="f976\.00.false.real.label"/> <parameter key="10" value="f3060\.00.false.real.label"/> <parameter key="11" value="f15300\.00.false.real.label"/> </list> </operator> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model (3)" width="90" x="313" y="300"> <list key="application_parameters"/> </operator> <operator activated="true" class="support_vector_machine_libsvm" compatibility="5.1.008" expanded="true" height="76" name="SVM2" width="90" x="112" y="210"> <parameter key="svm_type" value="epsilon-SVR"/> <parameter key="degree" value="2"/> <parameter key="gamma" value="0.5950000000000001"/> <parameter key="coef0" value="32.0"/> <parameter key="C" value="304.0"/> <list key="class_weights"/> </operator> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model" width="90" x="313" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" class="write_excel" compatibility="5.1.008" expanded="true" height="60" name="Write Excel" width="90" x="447" y="165"> <parameter key="excel_file" value="C:\Documents and Settings\Milan\My Documents\12.xls"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.1.008" expanded="true" height="76" name="Performance (3)" width="90" x="581" y="165"> <parameter key="main_criterion" value="correlation"/> <parameter key="root_mean_squared_error" value="false"/> <parameter key="correlation" value="true"/> </operator> <connect from_op="Read CSV" from_port="output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Normalize" from_port="preprocessing model" to_op="Apply Model (3)" to_port="model"/> <connect from_op="Multiply" from_port="output 1" to_op="SVM2" to_port="training set"/> <connect from_op="Multiply" from_port="output 2" to_op="OP" to_port="input 1"/> <connect from_op="OP" from_port="parameter" to_op="Set Parameters" to_port="parameter set"/> <connect from_op="Read CSV (3)" from_port="output" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="SVM2" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Write Excel" to_port="input"/> <connect from_op="Write Excel" from_port="through" to_op="Performance (3)" to_port="labelled data"/> <connect from_op="Performance (3)" from_port="performance" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="54"/> </process> </operator></process>
