<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="145" width="681"> <operator activated="true" class="generate_data" compatibility="5.1.008" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="1"/> <parameter key="number_of_attributes" value="1"/> </operator> <operator activated="true" class="select_attributes" compatibility="5.1.008" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.1.008" expanded="true" height="60" name="Extract Macro" width="90" x="313" y="30"> <parameter key="macro" value="tran_count"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="1"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.1.008" expanded="true" height="76" name="Generate Macro" width="90" x="447" y="30"> <list key="function_descriptions"> <parameter key="outlier_threshold" value="%{tran_count} * 0.2"/> </list> </operator> <operator activated="true" class="generate_attributes" compatibility="5.1.008" expanded="true" height="76" name="Generate Attributes" width="90" x="581" y="30"> <list key="function_descriptions"> <parameter key="threshold_test" value="%{outlier_threshold}"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
