Model description:
A set of gears
Load:Torque
Non-linear analysis conditions (NLSTAT)
There have contact between the gears (Slide)
Problem Description:
The ideal result should be that the largest stress is at the root of the tooth, but the analysis result is that the largest stress is at one point of the tooth surface.
This maybe stress concentration.
Is it a model problem? Or, if not, how to solve the stress concentration problem caused by this analysis.
When I look at the results at different times,
stress is still relatively uniform even at t=0.9, but stress concentration occurs at t=1.0.
Is the load equally divided?
The following pictures show the stress results
On the left is t=0.9. On the right is t=1.0.
