<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="346" width="949"> <operator activated="true" class="retrieve" compatibility="5.1.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="retrieve" compatibility="5.1.008" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="165"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.008" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="165"> <parameter key="name" value="Outlook"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="aggregate" compatibility="5.1.008" expanded="true" height="76" name="Aggregate" width="90" x="179" y="30"> <list key="aggregation_attributes"> <parameter key="Outlook" value="count"/> </list> <parameter key="group_by_attributes" value="|Outlook"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.1.008" expanded="true" height="76" name="Filter Examples" width="90" x="313" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="count(Outlook)>4"/> </operator> <operator activated="true" class="set_role" compatibility="5.1.008" expanded="true" height="76" name="Set Role" width="90" x="447" y="30"> <parameter key="name" value="Outlook"/> <parameter key="target_role" value="id"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="join" compatibility="5.1.008" expanded="true" height="76" name="Join" width="90" x="648" y="120"/> <connect from_op="Retrieve" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Join" to_port="right"/> <connect from_op="Aggregate" from_port="example set output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
Marco Boeck wrote:unfortunately, this is currently not as easy as we would like..
Marco Boeck wrote:I don't have your data, so I made an example process to illustrate how it can be done:
