Hello All,
I am new to use RADIOSS.
I do not know how to define property card for in RADIOSS for 4 node tetra elements and 8 node hex elements. I have defined ISOLID as 12 and I _tetra as 1 for hex and tetra elements respectively. Remaining fields were not defined.
I have used RBODY elements to connect the parts. When I give run, It is showing error with the message,
MESSAGE ID : 169
** STOP : ZERO OR NEGATIVE VOLUME
FOR 4 NODES TETRAHEDRON ID=121736, INTEGRATION POINT=1
I do not know how to solve this issue. Is there any options/ method to remove this error?
