<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process"> <parameter key="logverbosity" value="notes"/> <process expanded="true" height="190" width="413"> <operator activated="true" class="loop_parameters" compatibility="5.1.006" expanded="true" height="60" name="Loop Parameters" width="90" x="45" y="30"> <list key="parameters"> <parameter key="Set Macro.value" value="First,Second,Last One"/> </list> <process expanded="true" height="741" width="887"> <operator activated="true" class="set_macro" compatibility="5.1.006" expanded="true" height="60" name="Set Macro" width="90" x="45" y="30"> <parameter key="macro" value="text"/> <parameter key="value" value="Last One"/> </operator> <operator activated="true" class="print_to_console" compatibility="5.1.006" expanded="true" height="60" name="Print to Console" width="90" x="179" y="30"> <parameter key="log_value" value="This is line %{a}. The text is '%{text}'."/> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
