I have the following flow which uses a simple k-means and works perfectly (for my purpose at least!).
<process version="5.1.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process">
<parameter key="parallelize_main_process" value="false"/>
<process expanded="true" height="521" width="681">
<operator activated="true" class="read_csv" compatibility="5.1.006" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30">
<parameter key="csv_file" value="/Users/GiO/Desktop/csv/AlmostFull.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character_for_quotes" value="\"/>
<parameter key="skip_comments" value="false"/>
<parameter key="comment_characters" value="#"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="true"/>
<list key="annotations"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<list key="data_set_meta_data_information"/>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<operator activated="true" class="set_role" compatibility="5.1.006" expanded="true" height="76" name="Set Role" width="90" x="179" y="30">
<parameter key="name" value="favgame"/>
<operator activated="true" class="select_attributes" compatibility="5.1.006" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="30">
<parameter key="attribute_filter_type" value="value_type"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="polynominal"/>
<operator activated="true" class="replace_missing_values" compatibility="5.1.006" expanded="true" height="94" name="Replace Missing Values" width="90" x="447" y="30">
<parameter key="return_preprocessing_model" value="false"/>
<parameter key="create_view" value="false"/>
<parameter key="attribute_filter_type" value="no_missing_values"/>
<parameter key="default" value="zero"/>
<list key="columns"/>
<operator activated="true" class="k_means" compatibility="5.1.006" expanded="true" height="76" name="Clustering" width="90" x="246" y="390">
<parameter key="add_cluster_attribute" value="true"/>
<parameter key="add_as_label" value="false"/>
<parameter key="remove_unlabeled" value="false"/>
<parameter key="k" value="3"/>
<parameter key="max_runs" value="10"/>
<parameter key="max_optimization_steps" value="100"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="extract_prototypes" compatibility="5.1.006" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="380" y="300"/>
<operator activated="true" class="sort" compatibility="5.1.006" expanded="true" height="76" name="Sort" width="90" x="380" y="390">
<parameter key="attribute_name" value="cluster"/>
<parameter key="sorting_direction" value="increasing"/>
<connect from_op="Read CSV" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/>
<connect from_op="Replace Missing Values" from_port="example set output" to_op="Clustering" to_port="example set"/>
<connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/>
<connect from_op="Clustering" from_port="clustered set" to_op="Sort" to_port="example set input"/>
<connect from_op="Extract Cluster Prototypes" from_port="example set" to_port="result 1"/>
<connect from_op="Extract Cluster Prototypes" from_port="model" to_port="result 2"/>
<connect from_op="Sort" from_port="example set output" to_port="result 3"/>
<portSpacing port="sink_result 1" spacing="270"/>
<portSpacing port="sink_result 3" spacing="54"/>
</process>
</process>
Now I'd like to calculate its performance, but connecting Cluster Count Performance to Extract Cluster Prototypes' exa port gave a -0.000 for every cluster.
I have no idea if I'm doing something wrong or if that's the supposed result. Could you give any suggestions?
Thanks
EDIT: I couldn't care less for sorting the result anymore, feel free to delete it when working with my code.
