Hi there,
i'm a student and i work for a little project in my university i want to write a extension which calculate some values of different attributes.
I have bought the documention: 'how to extend rapidminer 5.0"
I currently stuck on Page 16! I want to compile the "RapidMiner_Extension_Tutorial" for testing. I think the build.xml values are correct, also i have followed al steps for eclipse
in
http://rapid-i.com/content/view/25/48/.But i don't understand how to excacly compile to get a .jar file in \plugins with eclipse.
When I press run 'RapidMiner_Vega' it gave me a bunch of error messages:
May 11, 2011 4:20:35 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: Property rapidminer.home is not set. Guessing.
INFO: Trying base directory of classes (build) 'E:\My Dropbox\ALaF Work\workspace\RapidMiner_Vega'...gotcha!
May 11, 2011 4:20:35 PM com.rapidminer.tools.ParameterService init
INFO: Reading configuration resource com/rapidminer/resources/rapidminerrc.
May 11, 2011 4:20:37 PM com.rapidminer.parameter.ParameterTypePassword decryptPassword
WARNING: Password in XML file looks like unencrypted plain text.
May 11, 2011 4:20:39 PM com.rapidminer.tools.plugin.Plugin registerOperators
INFO: No operator descriptor specified for plugin Community. Trying plugin initializtation class com.rapidminer.community.CommunityPluginInit.
WARNING: No operator descriptor defined for: Community
May 11, 2011 4:20:39 PM com.rapidminer.tools.OperatorService parseOperators
WARNING: Cannot load operator class: java.lang.NoClassDefFoundError: org/jdom/JDOMException
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.rapidminer.operator.OperatorDescription.<init>(OperatorDescription.java:93)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:259)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:256)
at com.rapidminer.tools.OperatorService.parseOperators(OperatorService.java:232)
at com.rapidminer.tools.OperatorService.registerOperators(OperatorService.java:206)
at com.rapidminer.tools.plugin.Plugin.registerOperators(Plugin.java:471)
at com.rapidminer.tools.plugin.Plugin.registerAllPluginOperators(Plugin.java:725)
at com.rapidminer.tools.OperatorService.init(OperatorService.java:167)
at com.rapidminer.RapidMiner.init(RapidMiner.java:465)
at com.rapidminer.gui.RapidMinerGUI.run(RapidMinerGUI.java:221)
at com.rapidminer.gui.RapidMinerGUI.launch(RapidMinerGUI.java:505)
at com.rapidminer.gui.RapidMinerGUI.main(RapidMinerGUI.java:488)
Caused by: java.lang.ClassNotFoundException: org.jdom.JDOMException
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at com.rapidminer.tools.plugin.PluginClassLoader.loadClass(PluginClassLoader.java:102)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 16 more
WARNING: Cannot load operator class: java.lang.NoClassDefFoundError: com/sun/syndication/io/FeedException
Caused by: java.lang.ClassNotFoundException: com.sun.syndication.io.FeedException
... 15 more
May 11, 2011 4:20:39 PM com.rapidminer.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for 'ODBC Bridge (e.g. Access)'
May 11, 2011 4:20:39 PM com.rapidminer.tools.jdbc.JDBCProperties registerDrivers
INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Probably the driver is not installed.
INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found. Probably the driver is not installed.
initGui(MainFrame mainFrame)
May 11, 2011 4:20:41 PM com.rapidminer.io.community.MyExperimentConnection connectTo
INFO: Connecting to: http://www.myexperiment.org/workflows.xml?num=100Can someone help please?
Thank you in advance!
-viktorious
