<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process"> <process expanded="true" height="161" width="346"> <operator activated="true" class="retrieve" compatibility="5.1.006" expanded="true" height="60" name="Retrieve" width="90" x="112" y="75"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.1.006" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="75"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="a1>7&&a2>3"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
