<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Root"> <process expanded="true" height="604" width="614"> <operator activated="true" class="retrieve" compatibility="5.1.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../data/Polynomial"/> </operator> <operator activated="true" class="split_data" compatibility="5.1.006" expanded="true" height="94" name="Split Data" width="90" x="179" y="120"> <enumeration key="partitions"> <parameter key="ratio" value="0.7"/> <parameter key="ratio" value="0.3"/> </enumeration> </operator> <operator activated="true" class="weight_by_relief" compatibility="5.1.006" expanded="true" height="76" name="Relief" width="90" x="313" y="30"/> <operator activated="true" class="select_by_weights" compatibility="5.1.006" expanded="true" height="94" name="AttributeWeightSelection" width="90" x="447" y="30"> <parameter key="weight" value="0.5"/> <parameter key="use_absolute_weights" value="false"/> </operator> <operator activated="true" class="select_by_weights" compatibility="5.1.006" expanded="true" height="94" name="AttributeWeightSelection (2)" width="90" x="514" y="165"> <parameter key="weight" value="0.5"/> <parameter key="use_absolute_weights" value="false"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_op="Relief" to_port="example set"/> <connect from_op="Split Data" from_port="partition 2" to_op="AttributeWeightSelection (2)" to_port="example set input"/> <connect from_op="Relief" from_port="weights" to_op="AttributeWeightSelection" to_port="weights"/> <connect from_op="Relief" from_port="example set" to_op="AttributeWeightSelection" to_port="example set input"/> <connect from_op="AttributeWeightSelection" from_port="example set output" to_port="result 1"/> <connect from_op="AttributeWeightSelection" from_port="weights" to_op="AttributeWeightSelection (2)" to_port="weights"/> <connect from_op="AttributeWeightSelection (2)" from_port="example set output" to_port="result 2"/> <connect from_op="AttributeWeightSelection (2)" from_port="weights" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
Forgive if it's a nonsense question..
