"R extension installation problem"
Hello ,
I have Fedora 14 installed on my system.
I have downloaded the zip file for rapidminer and extracted it to my home directory, i.e I did not do any compilation or installation
I then when in to lib directory of rapidminer and clicked on rapidminer.jar . Rapidminer opened up and then I updated all different extensions, including R.
I then erased R using
yum erase R
After that, I installed R using "yum install R"
version is 2.12.2
As the instructions mention, I typed
install.packages("rJava")
inside R and it got "rJava" package installed in
/usr/lib/R/library
Inside R, when I type .libPaths(), I get
[1] "/usr/lib/R/library" "/usr/share/R/library"
In PATH, I included
/usr/lib/R/lib:/usr/lib/R/bin
Here /usr/lib/R/lib contains libR.so .
R_HOME is set to
/usr/lib/R
JAVA_HOME is set to /etc/alternatives/java_sdk .
After clicking on "Next" button of "R Extension Installation Instructions" page, I pointed it to the directory
/usr/lib/R/library/rJava/jri
It is taking REngine.jar, even though the instructions say libjri.so is what it will be looking for.
I also get the message found library in
/usr/lib/R/library/rJava/jri/REngine.jar
(I later tried pointing to JRIEngine.jar and libjri.so, but same result)
The installation instruction mention the following
"If the new R Perspective has been added after restart, everything runs just fine. If not this dialog will show up again, please check if the file is in the correct directory, is accessible by RapidMiner"
Therefore, something is wrong as the window again shows up.
I have restarted the console so that environment variables are reset, verified them that they are all set correctly. Also, I unpacked rapidminer to a new different directory, after all the above are set. I also rebooted the computer (windows way). But, none of them worked.
I also tried removing R using yum erase and then installed R after compiling it. After that, I set the environment variables accordingly. But, the same loop is coming up.
When installing R by compiling from source, rJava version is 2.13.0. While installing using yum , it was either 2.12.0 or 2.12.2
Could anyone please help me out by giving some hints about what might be possibly be wrong and what else I can try to resolve this problem.
Thanks
Ajay
