<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process"> <process expanded="true" height="507" width="806"> <operator activated="true" class="retrieve" compatibility="5.1.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="retrieve" compatibility="5.1.008" expanded="true" height="60" name="Retrieve (2)" width="90" x="45" y="120"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="collect" compatibility="5.1.008" expanded="true" height="94" name="Collect" width="90" x="246" y="30"/> <operator activated="true" class="loop_collection" compatibility="5.1.008" expanded="true" height="76" name="Loop Collection" width="90" x="380" y="30"> <process expanded="true" height="525" width="806"> <operator activated="true" class="loop_parameters" compatibility="5.1.008" expanded="true" height="76" name="Loop Parameters" width="90" x="112" y="30"> <list key="parameters"> <parameter key="Select Subprocess.select_which" value="[1.0;3;3;linear]"/> </list> <process expanded="true" height="525" width="806"> <operator activated="true" class="select_subprocess" compatibility="5.1.008" expanded="true" height="76" name="Select Subprocess" width="90" x="45" y="30"> <parameter key="select_which" value="3"/> <process expanded="true" height="525" width="378"> <operator activated="true" class="x_validation" compatibility="5.1.008" expanded="true" height="112" name="Validation" width="90" x="45" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true" height="507" width="369"> <operator activated="true" class="decision_tree" compatibility="5.1.008" expanded="true" height="76" name="Decision Tree" width="90" x="144" y="30"/> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="507" width="369"> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.008" expanded="true" height="76" name="Perf(Decision Tree)" width="90" x="211" y="30"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Perf(Decision Tree)" to_port="labelled data"/> <connect from_op="Perf(Decision Tree)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="averagable 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> <process expanded="true" height="525" width="378"> <operator activated="true" class="x_validation" compatibility="5.1.008" expanded="true" height="112" name="Validation (2)" width="90" x="45" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true" height="507" width="369"> <operator activated="true" class="naive_bayes" compatibility="5.1.008" expanded="true" height="76" name="Naive Bayes" width="90" x="45" y="30"/> <connect from_port="training" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="507" width="369"> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model (2)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.008" expanded="true" height="76" name="Perf (NaiveBayes)" width="90" x="211" y="30"/> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Perf (NaiveBayes)" to_port="labelled data"/> <connect from_op="Perf (NaiveBayes)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Validation (2)" to_port="training"/> <connect from_op="Validation (2)" from_port="averagable 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> <process expanded="true" height="525" width="235"> <operator activated="true" class="x_validation" compatibility="5.1.008" expanded="true" height="112" name="Validation (3)" width="90" x="45" y="30"> <description>A cross-validation evaluating a decision tree model.</description> <process expanded="true" height="507" width="453"> <operator activated="true" class="nominal_to_binominal" compatibility="5.1.008" expanded="true" height="94" name="Nominal to Binominal" width="90" x="45" y="30"/> <operator activated="true" class="nominal_to_numerical" compatibility="5.1.008" expanded="true" height="94" name="Nominal to Numerical" width="90" x="179" y="30"/> <operator activated="true" class="linear_regression" compatibility="5.1.008" expanded="true" height="94" name="Linear Regression" width="90" x="313" y="30"/> <operator activated="true" class="group_models" compatibility="5.1.008" expanded="true" height="112" name="Group Models" width="90" x="313" y="165"/> <connect from_port="training" to_op="Nominal to Binominal" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Binominal" from_port="preprocessing model" to_op="Group Models" to_port="models in 1"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Linear Regression" to_port="training set"/> <connect from_op="Nominal to Numerical" from_port="preprocessing model" to_op="Group Models" to_port="models in 2"/> <connect from_op="Linear Regression" from_port="model" to_op="Group Models" to_port="models in 3"/> <connect from_op="Linear Regression" from_port="weights" to_port="through 1"/> <connect from_op="Group Models" from_port="model out" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true" height="507" width="369"> <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model (3)" width="90" x="45" y="30"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="5.1.008" expanded="true" height="76" name="Perf (LinearRegression)" width="90" x="211" y="30"/> <connect from_port="model" to_op="Apply Model (3)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/> <connect from_op="Apply Model (3)" from_port="labelled data" to_op="Perf (LinearRegression)" to_port="labelled data"/> <connect from_op="Perf (LinearRegression)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Validation (3)" to_port="training"/> <connect from_op="Validation (3)" from_port="averagable 1" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="multiply" compatibility="5.1.008" expanded="true" height="94" name="Multiply" width="90" x="425" y="30"/> <connect from_port="input 1" to_op="Select Subprocess" to_port="input 1"/> <connect from_op="Select Subprocess" from_port="output 1" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="performance"/> <connect from_op="Multiply" from_port="output 2" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_port="single" to_op="Loop Parameters" to_port="input 1"/> <connect from_op="Loop Parameters" from_port="result 1" to_port="output 1"/> <portSpacing port="source_single" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <operator activated="true" class="flatten_collection" compatibility="5.1.008" expanded="true" height="60" name="Flatten Collection" width="90" x="514" y="30"/> <connect from_op="Retrieve" from_port="output" to_op="Collect" to_port="input 1"/> <connect from_op="Retrieve (2)" from_port="output" to_op="Collect" to_port="input 2"/> <connect from_op="Collect" from_port="collection" to_op="Loop Collection" to_port="collection"/> <connect from_op="Loop Collection" from_port="output 1" to_op="Flatten Collection" to_port="collection"/> <connect from_op="Flatten Collection" from_port="flat" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
