edusr wrote:Hello,I just started to explore RM functionalities while using commercial packages for business purpose. It is a great open-source package. Appreciate the efforts from those guys behind.Does RM support any logic operations (e.g. attr1 > attr2?) among data/time attributes? Say, I wanted to select examples by defining a data_time attribute range through "Filter Examples," how do I write a constant of data_time type? Or can I generate such a value in any operators, and then make the comparison?Thank you!edusr
fritmore wrote:hidunno if it helps but try with Generate attributes operator that allows you to make math expressions with attributes generating so a new one.
Sebastian Land wrote:Hi,actually you pointed out one of the last very unconvenient parts of RapidMiner. The Filter Example operator will be changed completely in one of the next releases.But as already pointed out, you can use the Generate Attribute operator to evaluate any expression. You can later filter by the outcome of the expression using filter example again.Greetings, Sebastian
