"using Firebird DB with Rapidanalytics"
gvdamodar
I am evaluating RapidAnalytics for business purposes. I have installed Firebird DB, dropped the Jaybird jar file into lib folder, updated the Raidanalytics-ds.xml file as mentioned in the installation guide and then ran the run.bat. And the localhost:8080 link does not work as there are errors. The log file shows the following error:
java.lang.RuntimeException: Unable to inject jndi dependency: env/de.rapidanalytics.web.filter.AccessLogFilter/accessLogEJB into property de.rapidanalytics.web.filter.AccessLogFilter.accessLogEJB: RapidAnalytics not bound
How can this error be fixed? Details of the first error are given below.
Thanks in advance ...
regards.
Vijay
Error from boot.log file:
10:21:31,189 ERROR [[/RA]] Exception starting filter de.rapidanalytics.web.filter.AccessLogFilter: java.lang.RuntimeException: Unable to inject jndi dependency: env/de.rapidanalytics.web.filter.AccessLogFilter/accessLogEJB into property de.rapidanalytics.web.filter.AccessLogFilter.accessLogEJB: RapidAnalytics not bound
at org.jboss.injection.JndiPropertyInjector.lookup(JndiPropertyInjector.java:82)
at org.jboss.injection.JndiPropertyInjector.inject(JndiPropertyInjector.java:99)
at org.jboss.web.tomcat.service.TomcatInjectionContainer.processInjectors(TomcatInjectionContainer.java:388)
at org.jboss.web.tomcat.service.TomcatInjectionContainer.newInstance(TomcatInjectionContainer.java:284)
at org.jboss.web.tomcat.service.TomcatInjectionContainer.newInstance(TomcatInjectionContainer.java:278)
at org.jboss.web.tomcat.service.TomcatInjectionContainer.newInstance(TomcatInjectionContainer.java:261)
at org.apache.catalina.core.ApplicationFilterConfig.getFilter(ApplicationFilterConfig.java:444)
at org.apache.catalina.core.StandardContext.filterStart(StandardContext.java:3803)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4462)
at org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeployInternal(TomcatDeployment.java:315)
at org.jboss.web.tomcat.service.deployers.TomcatDeployment.performDeploy(TomcatDeployment.java:145)
at org.jboss.web.deployers.AbstractWarDeployment.start(AbstractWarDeployment.java:462)
at org.jboss.web.deployers.WebModule.startModule(WebModule.java:116)
at org.jboss.web.deployers.WebModule.start(WebModule.java:95)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.jboss.mx.interceptor.ReflectedDispatcher.invoke(ReflectedDispatcher.java:157)
at org.jboss.mx.server.Invocation.dispatch(Invocation.java:96)
at org.jboss.mx.server.Invocation.invoke(Invocation.java:88)
at org.jboss.mx.server.AbstractMBeanInvoker.invoke(AbstractMBeanInvoker.java:271)
at org.jboss.mx.server.MBeanServerImpl.invoke(MBeanServerImpl.java:670)
at org.jboss.system.microcontainer.ServiceProxy.invoke(ServiceProxy.java:206)
at $Proxy41.start(Unknown Source)
at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:53)
at org.jboss.system.microcontainer.StartStopLifecycleAction.installAction(StartStopLifecycleAction.java:41)
at org.jboss.dependency.plugins.action.SimpleControllerContextAction.simpleInstallAction(SimpleControllerContextAction.java:62)
at org.jboss.dependency.plugins.action.AccessControllerContextAction.install(AccessControllerContextAction.java:71)
at org.jboss.dependency.plugins.AbstractControllerContextActions.install(AbstractControllerContextActions.java:51)
at org.jboss.dependency.plugins.AbstractControllerContext.install(AbstractControllerContext.java:378)
at org.jboss.system.microcontainer.ServiceControllerContext.install(ServiceControllerContext.java:301)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:2029)
at org.jboss.dependency.plugins.AbstractController.incrementState(AbstractController.java:1050)
at org.jboss.dependency.plugins.AbstractController.executeOrIncrementStateDirectly(AbstractController.java:1289)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1213)
at org.jboss.dependency.plugins.AbstractController.resolveContexts(AbstractController.java:1107)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:918)
at org.jboss.dependency.plugins.AbstractController.change(AbstractController.java:633)
at org.jboss.system.ServiceController.doChange(ServiceController.java:671)
at org.jboss.system.ServiceController.start(ServiceController.java:443)
at org.jboss.system.deployers.ServiceDeployer.start(ServiceDeployer.java:189)
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:102)
at org.jboss.system.deployers.ServiceDeployer.deploy(ServiceDeployer.java:49)
at org.jboss.deployers.spi.deployer.helpers.AbstractSimpleRealDeployer.internalDeploy(AbstractSimpleRealDeployer.java:62)
at org.jboss.deployers.spi.deployer.helpers.AbstractRealDeployer.deploy(AbstractRealDeployer.java:55)
at org.jboss.deployers.plugins.deployers.DeployerWrapper.deploy(DeployerWrapper.java:179)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doDeploy(DeployersImpl.java:1660)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1378)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1399)
at org.jboss.deployers.plugins.deployers.DeployersImpl.doInstallParentFirst(DeployersImpl.java:1431)
at org.jboss.deployers.plugins.deployers.DeployersImpl.install(DeployersImpl.java:1319)
at org.jboss.deployers.plugins.deployers.DeployersImpl.process(DeployersImpl.java:898)
at org.jboss.deployers.plugins.main.MainDeployerImpl.process(MainDeployerImpl.java:677)
at org.jboss.system.server.profileservice.repository.MainDeployerAdapter.process(MainDeployerAdapter.java:117)
at org.jboss.system.server.profileservice.repository.ProfileDeployAction.install(ProfileDeployAction.java:70)
at org.jboss.system.server.profileservice.repository.AbstractProfileAction.install(AbstractProfileAction.java:53)
at org.jboss.system.server.profileservice.repository.AbstractProfileService.install(AbstractProfileService.java:403)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:873)
at org.jboss.dependency.plugins.AbstractController.install(AbstractController.java:620)
at org.jboss.system.server.profileservice.repository.AbstractProfileService.registerProfile(AbstractProfileService.java:308)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:259)
at org.jboss.system.server.profileservice.ProfileServiceBootstrap.start(ProfileServiceBootstrap.java:100)
at org.jboss.bootstrap.impl.base.server.AbstractServer.startBootstraps(AbstractServer.java:860)
at org.jboss.bootstrap.impl.base.server.AbstractServer$StartServerTask.run(AbstractServer.java:441)
at java.lang.Thread.run(Thread.java:662)
Caused by: javax.naming.NamingException: Could not dereference object [Root exception is javax.naming.NameNotFoundException: RapidAnalytics not bound]
at org.jnp.interfaces.NamingContext.resolveLink(NamingContext.java:1356)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:819)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:688)
at org.jboss.ejb3.JndiUtil.lookup(JndiUtil.java:44)
at org.jboss.injection.JndiPropertyInjector.lookup(JndiPropertyInjector.java:75)
... 79 more
Caused by: javax.naming.NameNotFoundException: RapidAnalytics not bound
at org.jnp.server.NamingServer.getBinding(NamingServer.java:771)
at org.jnp.server.NamingServer.getBinding(NamingServer.java:779)
at org.jnp.server.NamingServer.getObject(NamingServer.java:785)
at org.jnp.server.NamingServer.lookup(NamingServer.java:396)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:728)
at javax.naming.InitialContext.lookup(InitialContext.java:392)
at org.jnp.interfaces.NamingContext.resolveLink(NamingContext.java:1350)
... 83 more
Databases
fischer
when you go to the admin-console, do you see the data source listed and working?
Best,
Simon
