Hi guys,
I am sure you are aware about the progressive use of the processors of the NVIDIA GPU graphic boards to speed-up many softwares that require lots of computing power.
Recently the nd.com included a CUDA plug-in for its NeuroSolutions software.
In this link you can check how CUDA speed-up the processing:
http://www.neurosolutions.com/products/cuda/I would like to suggest to create a rapidminer add-on to allow users to use the CPU together with the available CUDA GPUs to increase the rapidminer performance. But remember to create a plug-in compatible with ALL CUDA graphic cards, and not only with heavy GPU systems like TESLA processor.
Most of the students have notebooks with cuda gpu cores. My own notebook have 32 cuda cores; other notebook have 96 or even more. Nvidia graphic cards for desktops have even more cores CUDA, hundreds.
So, do not repeat the NeuroSolutions software error, with a cuda add-on compatible just with some CUDA GPU versions (the most expensive types).
Matlab is another software with CUDA support. But, again, compatible just with the most expensive CUDA systems. And the students do not have access to such top GPU hardware.
http://www.mathworks.com/discovery/matlab-gpu.htmlSome information about the CUDA versions are available here:
http://www.nvidia.com/object/cuda_gpus.htmlI am sure most of the rapidminer users will appreciate this new feature.
Sukhoi
