<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.004"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.004" expanded="true" name="Process"> <parameter key="random_seed" value="-1"/> <process expanded="true" height="665" width="710"> <operator activated="true" class="generate_data" compatibility="5.1.004" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="gaussian mixture clusters"/> <parameter key="number_examples" value="1000"/> <parameter key="number_of_attributes" value="3"/> </operator> <operator activated="true" class="loop_parameters" compatibility="5.1.004" expanded="true" height="76" name="Loop Parameters" width="90" x="246" y="30"> <list key="parameters"> <parameter key="Clustering.k" value="[2.0;20;19;linear]"/> </list> <process expanded="true" height="665" width="710"> <operator activated="true" class="k_means" compatibility="5.1.004" expanded="true" height="76" name="Clustering" width="90" x="45" y="30"> <parameter key="k" value="20"/> <parameter key="max_runs" value="1000"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="2"/> </operator> <operator activated="true" class="cluster_distance_performance" compatibility="5.1.004" expanded="true" height="94" name="Performance" width="90" x="246" y="30"> <parameter key="normalize" value="true"/> </operator> <operator activated="true" class="log" compatibility="5.1.004" expanded="true" height="76" name="Log" width="90" x="447" y="30"> <list key="log"> <parameter key="DaviesBouldin" value="operator.Performance.value.DaviesBouldin"/> <parameter key="avgWithinDistance" value="operator.Performance.value.avg_within_distance"/> <parameter key="k" value="operator.Clustering.parameter.k"/> </list> </operator> <connect from_port="input 1" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Performance" to_port="cluster model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Performance" to_port="example set"/> <connect from_op="Performance" from_port="performance" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Parameters" to_port="input 1"/> <connect from_op="Loop Parameters" from_port="result 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
