"R extension problem"
geschwader
RapidMiner refuse to start after R extension being installed according to the instruction. Just exit after "loading icons".
Extensions
R
land
could you start RapidMiner using one of the scripts and post the console output here?
Do you use the latest versions of everything?
Greetings,
Sebastian
dynrep
I have the same problem. I see the splash screen for a little while, then it closes. When I run the RapidMinerGUI script, I get the output below. It repeats forever until I close the console. When I run rapidminer script, it closes the console before I can copy the text.
2011-05-02 17:40:16 INFO: Creating Connection to R... (Rengine.<clinit>())
2011-05-02 17:40:16 INFO: Trying to loaded R library from C:\Users\User1\Docum
ents\R\win-library\2.13\rJava\jri\x64\jri.dll (Rengine.loadLibrary())
2011-05-02 17:40:16 INFO: Engine ID: class org.rosuda.JRI.Rengine ClassLoader:Pl
uginClassLoader ([file:/C:/Users/User1/.RapidMiner5/managed/rmx_r-5.1.3.jar])
2011-05-02 17:40:16 INFO: Successfully loaded R library from C:\Users\User1\Do
cuments\R\win-library\2.13\rJava\jri\x64\jri.dll(true) (Rengine.loadLibrary())
2011-05-02 17:40:16 CONFIG: Loading operators from 'OperatorsCore.xml'. (Operato
rService.registerOperators())
2011-05-02 17:40:16 CONFIG: Loading operator documentation from jar:file:/C:/Pro
gram%20Files/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/i1
8n/OperatorsCoreDocumentation.xml. (OperatorDocBundle$XMLControl.newBundle())
2011-05-02 17:40:18 WARNING: Password in XML file looks like unencrypted plain t
ext. (ParameterTypePassword.decryptPassword())
2011-05-02 17:40:19 CONFIG: Loading operators from 'C:\Users\User1\.RapidMiner
5\managed\rmx_r-5.1.3.jar'. (OperatorService.registerOperators())
2011-05-02 17:40:19 CONFIG: Loading operator documentation from jar:file:/C:/Use
rs/User1/.RapidMiner5/managed/rmx_r-5.1.3.jar!/com/rapidminer/resources/i18n/O
peratorsDocR.xml. (OperatorDocBundle$XMLControl.newBundle())
2011-05-02 17:40:19 CONFIG: Creating operators from factory com.rapidminer.opera
tor.r.ROperatorFactory (OperatorService.parseOperators())
2011-05-02 17:40:19 CONFIG: Number of registered operator classes: 418; number o
f registered operator descriptions: 436; number of replacements: 404 (OperatorSe
rvice.init())
2011-05-02 17:40:19 CONFIG: Loading operator usage statistics. (UsageStatistics.
load())
2011-05-02 17:40:19 CONFIG: Reading parse rules from jar:file:/C:/Program%20File
s/Rapid-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/parserules.xm
l (XMLImporter.importParseRules())
2011-05-02 17:40:19 CONFIG: Loading JDBC driver information from 'resource jdbc_
properties.xml'. (DatabaseService.loadJDBCProperties())
2011-05-02 17:40:19 CONFIG: Loaded JDBC driver com.mysql.jdbc.Driver (JDBCProper
ties.registerDrivers())
2011-05-02 17:40:19 CONFIG: Loaded JDBC driver org.postgresql.Driver (JDBCProper
2011-05-02 17:40:19 CONFIG: Loaded JDBC driver net.sourceforge.jtds.jdbc.Driver
(JDBCProperties.registerDrivers())
2011-05-02 17:40:19 CONFIG: Loaded JDBC driver org.hsqldb.jdbcDriver (JDBCProper
2011-05-02 17:40:19 WARNING: Missing database driver class name for 'ODBC Bridge
(e.g. Access)' (JDBCProperties.<init>())
2011-05-02 17:40:19 CONFIG: Loaded JDBC driver com.ingres.jdbc.IngresDriver (JDB
2011-05-02 17:40:19 INFO: JDBC driver ca.ingres.jdbc.IngresDriver not found. Pro
bably the driver is not installed. (JDBCProperties.registerDrivers())
2011-05-02 17:40:19 INFO: JDBC driver oracle.jdbc.driver.OracleDriver not found.
Probably the driver is not installed. (JDBCProperties.registerDrivers())
2011-05-02 17:40:19 CONFIG: Neither system property 'rapidminer.config.dir' nor
environment variable 'RAPIDMINER_CONFIG_DIR' not set. Ignored. (ParameterService
.getGlobalConfigDir())
2011-05-02 17:40:19 CONFIG: Loading repositories from C:\Users\User1\.RapidMin
er5\repositories.xml (RepositoryManager.load())
2011-05-02 17:40:19 CONFIG: Adding repository NewLocalRepository (RepositoryMana
ger.addRepository())
2011-05-02 17:40:19 CONFIG: Loading renderers from 'file:/C:/Program%20Files/Rap
id-I/RapidMiner5/lib/rapidminer.jar!/com/rapidminer/resources/ioobjects.xml'. (R
endererService.init())
2011-05-02 17:40:19 CONFIG: Loading renderers from 'ioobjects.xml'. (RendererSer
vice.init())
2011-05-02 17:40:21 CONFIG: Loading perspectives. (ApplicationPerspectives.loadA
ll())
Starting RapidMiner from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..' using
classes from 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..\lib\rapidminer.ja
r'...
May 2, 2011 5:40:21 PM com.rapid_i.Launcher ensureRapidMinerHomeSet
INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMiner5\scripts\..'.
May 2, 2011 5:40:21 PM com.rapid_i.Launcher main
INFO: Launching RapidMiner, platform WIN64
2011-05-02 17:40:22 CONFIG: Locale not specified explicitly. Set default locale
to US. (RapidMiner.init())
2011-05-02 17:40:22 INFO: rapidminer.home is 'C:\Program Files\Rapid-I\RapidMine
r5\scripts\..'. (Launcher.ensureRapidMinerHomeSet())
2011-05-02 17:40:22 CONFIG: Reading configuration resource com/rapidminer/resour
ces/rapidminerrc. (ParameterService.loadAllRCFiles())
2011-05-02 17:40:22 CONFIG: Neither system property 'rapidminer.config.dir' nor
2011-05-02 17:40:22 CONFIG: Trying rcfile 'C:\Users\User1\.RapidMiner5\5_1_006
_rapidminerrc'...skipped (ParameterService.loadRCFile())
2011-05-02 17:40:22 CONFIG: Read rcfile 'C:\Users\User1\.RapidMiner5\5_1_006_r
apidminerrc.Windows 7'. (ParameterService.loadRCFile())
2011-05-02 17:40:22 CONFIG: Trying rcfile 'C:\Program Files\Rapid-I\RapidMiner5\
rapidminerrc.Windows 7'...skipped (ParameterService.loadRCFile())
2011-05-02 17:40:22 CONFIG: Property rapidminer.rcfile not specified...skipped (
2011-05-02 17:40:22 CONFIG: Read extension state. (ManagedExtension.readConfigur
ation())
2011-05-02 17:40:22 CONFIG: Scanning plugins in C:\Program Files\Rapid-I\RapidMi
ner5\scripts\..\lib\plugins. (Plugin.findAndRegisterPlugins())
2011-05-02 17:40:22 CONFIG: Loading renderers from 'R Extension'. (RendererServi
ce.init())
2011-05-02 17:40:22 CONFIG: Reading parse rules from jar:file:/C:/Users/User1/
.RapidMiner5/managed/rmx_r-5.1.3.jar!/com/rapidminer/resources/parserulesR.xml (
2011-05-02 17:40:22 INFO: Trying to load R Library... (PluginInitR.initPlugin())
2011-05-02 17:40:22 INFO: Creating Connection to R... (Rengine.<clinit>())
2011-05-02 17:40:22 INFO: Trying to loaded R library from C:\Users\User1\Docum
2011-05-02 17:40:22 INFO: Engine ID: class org.rosuda.JRI.Rengine ClassLoader:Pl
2011-05-02 17:40:22 INFO: Successfully loaded R library from C:\Users\User1\Do
2011-05-02 17:40:22 CONFIG: Loading operators from 'OperatorsCore.xml'. (Operato
2011-05-02 17:40:22 CONFIG: Loading operator documentation from jar:file:/C:/Pro
2011-05-02 17:40:24 WARNING: Password in XML file looks like unencrypted plain t
2011-05-02 17:40:25 CONFIG: Loading operators from 'C:\Users\User1\.RapidMiner
nandadorea
I have the exact same problem. everything just as described above. I am using R 2.12.2 64bit
nandadorea
I just uninstalled and installed RapidMiner again - because now I just want a way to get back on RapidMiner, whether the extension works or not - and it still does the same thing. So right now, I cannot use RapidMiner from my computer at all!! anyone, any idea? help please....
IngoRM
you could remove the extension manually before starting RapidMiner. Usually, the extensions are installed in your home directory under .rapidminer5/extensions. Please note that the directory ".rapidminer5" might be hidden. You could simply remove the extension file from there and also the entry in the corresponding xml file.
More information about removing extensions manually can be found here:
http://rapid-i.com/rapidforum/index.php/topic,2894.msg11509.html#msg11509
Cheers,
Ingo
nandadorea
Thank you! I hope to have better luck with the extension in the near future, as I was really looking forward using it. I will post any luck I get on that.
