Matthias wrote:Hi,I think all the Import Data Operators couldn't prepare the meta data informations directly.Because only when you start the process RM can read the meta data informations. The easiest way is to save the dataset with the store operator at the repository. And then you have an fast acces to the dataset with the Retrieve operator. And alway the meta data informations.Greetings Matthias
Sebastian Land wrote:Hi,let me formulate it in this way: Do you use the Community Edition?Greetings, Sebastian
