Please note your can define a logical OR of several conditions with || and a logical AND of two conditions with two ampersand (condition1 && condition2) - or simply by applying several ExampleFilter operators in a row. Please note also that for nominal attributes you can define a regular expression for value of the possible equal and not equal checks.To filter all examples (i.e. rows) where an attribute "att" has a missing value use the expression "att = ?" resp. "att!= ?". Note that for nominal values the question mark must be escaped ("\?") because, as noted above, a regular expression is expected in this case.For "unknown_attributes" the parameter string must be empty. This filter removes all examples containing attributes that have missing or illegal values. For "unknown_label" the parameter string must also be empty. This filter removes all examples with an unknown label value.
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.003" expanded="true" name="Process"> <process expanded="true" height="370" width="346"> <operator activated="true" class="generate_data" compatibility="5.1.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="165"/> <operator activated="true" class="filter_examples" compatibility="5.1.003" expanded="true" height="76" name="Filter Examples" width="90" x="246" y="210"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="att1<0 || att2 > 0"/> <parameter key="invert_filter" value="true"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process
