Hello
I'm trying to join two example sets using the outer join option but I've observed that the operator behaves differently depening on which order the left and right inputs are presented.
I've made an example that shows this; if the inputs are swapped the results change.
Am I right to think the order should not make a difference?
regards
Andrew
<process version="5.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.001" expanded="true" name="Process">
<process expanded="true" height="686" width="858">
<operator activated="true" class="generate_data" compatibility="5.1.001" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30">
<parameter key="number_examples" value="1"/>
<parameter key="number_of_attributes" value="2"/>
<operator activated="true" class="select_attributes" compatibility="5.1.001" expanded="true" height="76" name="Select Attributes" width="90" x="45" y="120">
<operator activated="true" class="generate_id" compatibility="5.1.001" expanded="true" height="76" name="Generate ID" width="90" x="45" y="210"/>
<operator activated="true" class="generate_attributes" compatibility="5.1.001" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="210">
<parameter key="a1" value="10+id"/>
<parameter key="a2" value="20+id"/>
</list>
<operator activated="true" class="declare_missing_value" compatibility="5.1.001" expanded="true" height="76" name="Declare Missing Value" width="90" x="179" y="75">
<parameter key="attribute" value="a2"/>
<parameter key="numeric_value" value="21.0"/>
<operator activated="true" class="generate_data" compatibility="5.1.001" expanded="true" height="60" name="Generate Data (2)" width="90" x="45" y="525">
<parameter key="number_examples" value="2"/>
<operator activated="true" class="select_attributes" compatibility="5.1.001" expanded="true" height="76" name="Select Attributes (2)" width="90" x="45" y="435">
<operator activated="true" class="generate_id" compatibility="5.1.001" expanded="true" height="76" name="Generate ID (2)" width="90" x="45" y="345"/>
<operator activated="true" class="generate_attributes" compatibility="5.1.001" expanded="true" height="76" name="Generate Attributes (2)" width="90" x="179" y="345">
<parameter key="a3" value="30+id"/>
</list>
<operator activated="true" class="multiply" compatibility="5.1.001" expanded="true" height="94" name="Multiply" width="90" x="380" y="75"/>
<operator activated="true" class="multiply" compatibility="5.1.001" expanded="true" height="94" name="Multiply (2)" width="90" x="380" y="435"/>
<operator activated="true" class="join" compatibility="5.1.001" expanded="true" height="76" name="Join" width="90" x="514" y="255">
<parameter key="join_type" value="outer"/>
<connect from_op="Generate Data" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Declare Missing Value" to_port="example set input"/>
<connect from_op="Declare Missing Value" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Generate Data (2)" from_port="output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Generate ID (2)" to_port="example set input"/>
<connect from_op="Generate ID (2)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/>
<connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_port="result 2"/>
<connect from_op="Multiply" from_port="output 2" to_op="Join" to_port="right"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Join" to_port="left"/>
<connect from_op="Multiply (2)" from_port="output 2" to_port="result 3"/>
<connect from_op="Join" from_port="join" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="198"/>
</process>
</process>
