<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.000" expanded="true" name="Process"> <process expanded="true" height="476" width="815"> <operator activated="true" class="generate_data" compatibility="5.1.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="three ring clusters"/> <parameter key="number_of_attributes" value="2"/> </operator> <operator activated="true" class="normalize" compatibility="5.1.000" expanded="true" height="94" name="Normalize" width="90" x="246" y="75"> <parameter key="method" value="range transformation"/> </operator> <operator activated="true" class="set_macros" compatibility="5.1.000" expanded="true" height="76" name="Set Macros" width="90" x="447" y="75"> <list key="macros"> <parameter key="epsilonStart" value="0.005"/> <parameter key="epsilonIncrement" value="0.002"/> <parameter key="loopCounter" value="0"/> <parameter key="maxLoop" value="10"/> </list> </operator> <operator activated="true" class="loop" compatibility="5.1.000" expanded="true" height="76" name="Loop" width="90" x="648" y="75"> <parameter key="iterations" value="%{maxLoop}"/> <process expanded="true" height="579" width="984"> <operator activated="true" class="generate_macro" compatibility="5.1.000" expanded="true" height="76" name="Generate Macro" width="90" x="112" y="30"> <list key="function_descriptions"> <parameter key="epsilon" value="%{epsilonStart}+%{epsilonIncrement}*%{loopCounter}"/> <parameter key="loopCounter" value="%{loopCounter}+1"/> </list> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.1.000" expanded="true" height="76" name="Provide Macro as Log Value (2)" width="90" x="246" y="30"> <parameter key="macro_name" value="epsilon"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.1.000" expanded="true" height="94" name="Optimize Parameters (Grid)" width="90" x="380" y="30"> <list key="parameters"> <parameter key="Clustering.min_points" value="[2;21;20;linear]"/> </list> <process expanded="true" height="579" width="984"> <operator activated="true" class="dbscan" compatibility="5.1.000" expanded="true" height="76" name="Clustering" width="90" x="179" y="165"> <parameter key="epsilon" value="%{epsilon}"/> <parameter key="min_points" value="21"/> </operator> <operator activated="true" class="cluster_count_performance" compatibility="5.1.000" expanded="true" height="76" name="Count" width="90" x="313" y="165"/> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.1.000" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="514" y="165"> <parameter key="macro_name" value="loopCounter"/> </operator> <operator activated="true" class="log" compatibility="5.1.000" expanded="true" height="76" name="Log (3)" width="90" x="715" y="165"> <list key="log"> <parameter key="epsilon" value="operator.Provide Macro as Log Value (2).value.macro_value"/> <parameter key="epsilonMissingFromDBSCAN" value="operator.Clustering.parameter."/> <parameter key="minPoints" value="operator.Clustering.parameter.min_points"/> <parameter key="loopCounter" value="operator.Provide Macro as Log Value.value.macro_value"/> <parameter key="clusterNumber" value="operator.Count.value.clusternumber"/> </list> </operator> <connect from_port="input 1" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Count" to_port="cluster model"/> <connect from_op="Count" from_port="performance" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log (3)" to_port="through 1"/> <connect from_op="Log (3)" from_port="through 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="180"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Provide Macro as Log Value (2)" to_port="through 1"/> <connect from_op="Provide Macro as Log Value (2)" from_port="through 1" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="output 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Set Macros" to_port="through 1"/> <connect from_op="Set Macros" from_port="through 1" to_op="Loop" to_port="input 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
<parameter key="epsilonMissingFromDBSCAN" value="operator.Clustering.parameter.epsilon"/>
