I get the following errors when I try and run a simulation with the Adaboost component:
Exception: com.rapidminer.example.AttributeTypeException
Message: Cannot map index of nominal attribute to nominal value: index 4 is out of bounds!
Stack trace:
com.rapidminer.example.table.PolynominalMapping.mapIndex(PolynominalMapping.java:137)
com.rapidminer.operator.learner.meta.AdaBoostModel.evaluateSpecialAttributes(AdaBoostModel.java:231)
com.rapidminer.operator.learner.meta.AdaBoostModel.performPrediction(AdaBoostModel.java:166)
com.rapidminer.operator.learner.PredictionModel.apply(PredictionModel.java:76)
com.rapidminer.operator.ModelApplier.doWork(ModelApplier.java:100)
com.rapidminer.operator.Operator.execute(Operator.java:771)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:709)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:368)
com.rapidminer.Process.run(Process.java:899)
com.rapidminer.Process.run(Process.java:795)
com.rapidminer.Process.run(Process.java:790)
com.rapidminer.Process.run(Process.java:780)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:62)
Here's the setup:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process">
<process expanded="true" height="341" width="605">
<operator activated="true" class="retrieve" compatibility="5.0.11" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30">
<parameter key="repository_entry" value="//NewLocalRepository/SPY_test_data"/>
<operator activated="true" class="retrieve" compatibility="5.0.11" expanded="true" height="60" name="Retrieve (2)" width="90" x="99" y="164">
<parameter key="repository_entry" value="//NewLocalRepository/SPY_apply_model"/>
<operator activated="true" class="series:windowing" compatibility="5.0.2" expanded="true" height="76" name="Windowing" width="90" x="179" y="30">
<parameter key="horizon" value="1"/>
<parameter key="window_size" value="1"/>
<parameter key="create_label" value="true"/>
<parameter key="label_attribute" value="ROC-1"/>
<operator activated="true" class="adaboost" compatibility="5.0.11" expanded="true" height="76" name="AdaBoost" width="90" x="357" y="35">
<process expanded="true" height="315" width="605">
<operator activated="true" class="parallel:decision_tree_weight_based_parallel" compatibility="5.0.1" expanded="true" height="60" name="DecisionTree (Weight-Based)" width="90" x="243" y="58">
<process expanded="true">
<portSpacing port="source_training set" spacing="0"/>
<portSpacing port="sink_weights" spacing="0"/>
</process>
<connect from_port="training set" to_op="DecisionTree (Weight-Based)" to_port="training set"/>
<connect from_op="DecisionTree (Weight-Based)" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.0.11" expanded="true" height="76" name="Apply Model (2)" width="90" x="380" y="210">
<connect from_op="Retrieve" from_port="output" to_op="Windowing" to_port="example set input"/>
<connect from_op="Retrieve (2)" from_port="output" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Windowing" from_port="example set output" to_op="AdaBoost" to_port="training set"/>
<connect from_op="AdaBoost" from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 1"/>
</process>
</process>
I've submitted the bug, but I was wondering if anyone had any insight as to what I'm doing wrong.
Thanks!
