"Can a groovy script count clusters?"
Hello all,
The Cluster Count Performance operator returns very odd values. I decided to look at the code to see what was going on and I noticed these lines in the file 'ClusterNumberEvaluator.java' at about line 90
This gets used later in this line
Anyway my question, before I embark on it, will it be possible to use the Groovy scrting operator to calcuate this myself?
regards
Andrew
numitems is set to one more than the number of examples in the last cluster.
for (int i = 0; i < model.getNumberOfClusters(); i++)
numItems = +model.getCluster(i).getNumberOfExamples();
So leads to weird values. I think numItems += model should fix it.
PerformanceCriterion pc = new EstimatedPerformance("Number of clusters", 1.0 - (((double) model.getNumberOfClusters()) / ((double) numItems)), 1, false);
regards
Andrew
1 - 2 of
21
ok, that's a typo causing a lot of headache
Additionally I have changed the behavior of the operator so that it now returns two criterions one containing the actual number.
And of course you can do this with the Grovy Scripting operator.
Greetings,
Sebastian
