I've been experimenting with the REST API from LastFM. My query to the API asks for artists similar to Bono.
Here's the XML file that the query generates:
http://ws.audioscrobbler.com/2.0/?method=artist.getsimilar&;artist=bono&api_key=b25b959554ed76058ac220b7b2e0a026
I'm trying to parse the XML file and generate output that provides "artist" and "match" for each of the 100 entries in the XML file. The current output generates 200 rows containing the URL I'm querying, the full contents of the page, and the name of the attributes I setup with XPATH queries. The output I want to see is a different artist name and associated match number on each row. Any advice on how to achieve this is greatly appreciated.
Thanks,
Jamie
This is what I want to see in the Data View:
This is what I currently see in the Data View:
Here's my process:
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.8" expanded="true" name="Process">
<process expanded="true" height="628" width="736">
<operator activated="true" class="web:process_web" compatibility="5.0.4" expanded="true" height="60" name="Process Documents from Web" width="90" x="45" y="30">
<parameter key="url" value="http://ws.audioscrobbler.com/2.0/?method=artist.getsimilar&artist=bono&api_key=b25b959554ed76058ac220b7b2e0a026"/>
<list key="crawling_rules">
<parameter key="0" value="http://ws.audioscrobbler.com/2.0/?method=artist.getsimilar&artist=bono&api_key=b25b959554ed76058ac220b7b2e0a026"/>
</list>
<parameter key="add_pages_as_attribute" value="true"/>
<parameter key="max_pages" value="1"/>
<process expanded="true" height="481" width="788">
<operator activated="true" class="text:cut_document" compatibility="5.0.7" expanded="true" height="60" name="Cut Document" width="90" x="70" y="46">
<parameter key="query_type" value="XPath"/>
<list key="string_machting_queries"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries">
<parameter key="name" value="/h:lfm/h:similarartists/h:artist/h:name"/>
<parameter key="match" value="/h:lfm/h:similarartists/h:artist/h:match"/>
</list>
<list key="namespaces"/>
<list key="index_queries"/>
<process expanded="true" height="463" width="702">
<connect from_port="segment" to_port="document 1"/>
<portSpacing port="source_segment" spacing="0"/>
</process>
<connect from_port="document" to_op="Cut Document" to_port="document"/>
<connect from_op="Cut Document" from_port="documents" to_port="document 1"/>
</process>
<operator activated="true" class="write_database" compatibility="5.0.8" expanded="true" height="60" name="Write Database" width="90" x="246" y="30">
<parameter key="connection" value="AWS RDS"/>
<parameter key="table_name" value="artists"/>
<parameter key="overwrite_mode" value="append"/>
<connect from_op="Process Documents from Web" from_port="example set" to_op="Write Database" to_port="input"/>
<connect from_op="Write Database" from_port="through" to_port="result 1"/>
</process>
</process>
