as I couldn't find any thing on the forum, I have to start a new thread.
I'm using Rapidminer 5.0.11 (MacOS) and I when I use the "read database" operator to connect to a MySQL DB, I can't see any results in the preview nor can I select any columns in a following operator. The connection works fine. When I test it in the "read database" operator it says connection successful. But no data is shown or read...
Doesn't matter if I select "define query tablename / query".
Thanks for any hint!
Best regards,
Andi
