since the operator "Append" (for combining results from "Loop Examples") seems to need more memory than available, I changed the output strategy from a final big excel file to inremental database writing inside the loop. I took "Write Database" set overwrite mode to 'overwrite first, append then', configured the DB connection (mySQL), set the table name and started the process. There was one attribute ('description') generating too long content for varchar, so I converted this one to text and the output was starting. After writing some lines I got the next error message saying that a certain attribute value is too long for the respective column. I discovered that all the varchar columns were declared with the length of the first example's values. For this problem the 'set default varchar length' parameter offered a promising solution. So I set this default length to 250 and tried another run. Ooops, now the error message said that the 'description' attribute value was too long for the default varchar length. But this one should be of type text anyway. After setting the default length the value for 'table name' was cleared everytime I revisited the "Write Database" operator. I found no way of getting it back in there without removing the operator and adding a fresh one. So this whole thing seems a bit buggy, for the current run I am using type 'text' for all my attributes. But this solution isn't too satisfying...
Can someone confirm there problems? Any suggestions?
I am using the latest development version available through subversion.
Thanks and best regards,
Matthias
