<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process"> <process expanded="true" height="145" width="212"> <operator activated="true" class="generate_data" compatibility="5.0.11" expanded="true" height="60" name="Generate Data" width="90" x="112" y="75"/> <operator activated="true" class="generate_attributes" compatibility="5.0.11" expanded="true" height="76" name="Generate Attributes" width="90" x="308" y="74"> <list key="function_descriptions"> <parameter key="myFirstRandomNumber" value="rand()"/> <parameter key="mySecondRandomNumber" value="3*rand()+4"/> </list> <parameter key="keep_all" value="false"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
