I've used this basic train/apply model successfully for other text classification jobs, but now it is producing an error. Removing stemming and token filtering by size in the apply section of Process Documents still produces an error. Version is 5.0.11 and text module is 5.0.7.
Any ideas about what to change? The text is coming from the same table/field. Training text is a subset of the full set of documents in the table.
Exception: com.rapidminer.operator.UserError
Message: The attribute text was already present in the example set.
Stack trace:
com.rapidminer.operator.text.io.AbstractDocumentInputOperator.createWordAttributes(AbstractDocumentInputOperator.java:336)
com.rapidminer.operator.text.io.AbstractDocumentInputOperator.doWork(AbstractDocumentInputOperator.java:243)
com.rapidminer.operator.Operator.execute(Operator.java:771)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:709)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:368)
com.rapidminer.Process.run(Process.java:899)
com.rapidminer.Process.run(Process.java:795)
com.rapidminer.Process.run(Process.java:790)
com.rapidminer.Process.run(Process.java:780)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:62)
Nov 22, 2010 10:19:39 AM SEVERE: Process failed: The attribute text was already present in the example set.
Nov 22, 2010 10:19:39 AM SEVERE: Here: Root[1] (Process)
subprocess 'Main Process'
+- Read Database[1] (Read Database)
+- Set Role[0] (Set Role)
+- Set Role (2)[1] (Set Role)
+- Replace[1] (Replace)
+- Nominal to Text[1] (Nominal to Text)
+- Process Documents from Data[1] (Process Documents from Data)
subprocess 'Vector Creation'
| +- Transform Cases[19098] (Transform Cases)
| +- Tokenize[19098] (Tokenize)
| +- Filter Stopwords (2)[19098] (Filter Stopwords (English))
| +- Stem (2)[19098] (Stem (Porter))
| +- Filter Tokens (by Length)[19098] (Filter Tokens (by Length))
| +- Extract Token Number[19098] (Extract Token Number)
+- SVM[1] (Support Vector Machine (LibSVM))
+- Read Database (2)[1] (Read Database)
+- Replace (2)[1] (Replace)
+- Set Role (3)[1] (Set Role)
+- Set Role (4)[0] (Set Role)
+- Nominal to Text (2)[1] (Nominal to Text)
+- Process Documents from Data (2)[1] (Process Documents from Data)
| +- Transform Cases (2)[1] (Transform Cases)
==> | +- Tokenize (2)[1] (Tokenize)
| +- Filter Stopwords (English)[0] (Filter Stopwords (English))
| +- Filter Tokens (2)[0] (Filter Tokens (by Length))
| +- Stem (Porter)[0] (Stem (Porter))
| +- Extract Token Number (2)[0] (Extract Token Number)
+- Apply Model[0] (Apply Model)
Nov 22, 2010 10:19:39 AM SEVERE: The attribute text was already present in the example set.
<process version="5.0">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.0.0" expanded="true" name="Root">
<description>Using a simple Naive Bayes classifier.</description>
<process expanded="true" height="656" width="949">
<operator activated="true" class="read_database" compatibility="5.0.10" expanded="true" height="60" name="Read Database" width="90" x="45" y="570">
<list key="data_set_meta_data_information"/>
<parameter key="attribute_names_already_defined" value="true"/>
<parameter key="connection" value="sql_work"/>
<parameter key="query" value="SELECT "category", "doctext" FROM "traindocs" WHERE "filter" = 'test' "/>
<operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="Set Role (2)" width="90" x="45" y="390">
<parameter key="name" value="category"/>
<operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace" width="90" x="179" y="390">
<parameter key="attribute" value="doctext"/>
<parameter key="regular_expression" value="http.* "/>
<parameter key="replace_what" value="http.*\s|#\w+\s|@\w*\s"/>
<operator activated="true" class="nominal_to_text" compatibility="5.0.10" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="480">
<parameter key="attributes" value="posttitle|postdesc"/>
<operator activated="true" class="text:process_document_from_data" compatibility="5.0.6" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="300">
<list key="specify_weights"/>
<process expanded="true" height="565" width="882">
<operator activated="true" class="text:transform_cases" compatibility="5.0.6" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="30"/>
<operator activated="true" class="text:tokenize" compatibility="5.0.6" expanded="true" height="60" name="Tokenize" width="90" x="179" y="30"/>
<operator activated="true" class="text:filter_stopwords_english" compatibility="5.0.7" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="313" y="30"/>
<operator activated="true" class="text:stem_porter" compatibility="5.0.7" expanded="true" height="60" name="Stem (2)" width="90" x="447" y="30"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.0.7" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="648" y="30">
<parameter key="min_chars" value="2"/>
<operator activated="true" class="text:extract_token_number" compatibility="5.0.7" expanded="true" height="60" name="Extract Token Number" width="90" x="794" y="45"/>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
<connect from_op="Filter Stopwords (2)" from_port="document" to_op="Stem (2)" to_port="document"/>
<connect from_op="Stem (2)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Extract Token Number" to_port="document"/>
<connect from_op="Extract Token Number" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="support_vector_machine_libsvm" compatibility="5.0.10" expanded="true" height="76" name="SVM" width="90" x="514" y="255">
<parameter key="kernel_type" value="linear"/>
<list key="class_weights"/>
<operator activated="true" class="read_database" compatibility="5.0.10" expanded="true" height="60" name="Read Database (2)" width="90" x="45" y="30">
<parameter key="query" value="SELECT "id", "doctext" FROM "traindocs" "/>
<operator activated="true" class="replace" compatibility="5.0.10" expanded="true" height="76" name="Replace (2)" width="90" x="179" y="30">
<parameter key="attribute" value="text"/>
<operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="Set Role (3)" width="90" x="45" y="120">
<parameter key="name" value="id"/>
<operator activated="true" class="nominal_to_text" compatibility="5.0.10" expanded="true" height="76" name="Nominal to Text (2)" width="90" x="179" y="120">
<operator activated="true" class="text:process_document_from_data" compatibility="5.0.6" expanded="true" height="76" name="Process Documents from Data (2)" width="90" x="313" y="120">
<parameter key="keep_text" value="true"/>
<process expanded="true" height="657" width="882">
<operator activated="true" class="text:transform_cases" compatibility="5.0.6" expanded="true" height="60" name="Transform Cases (2)" width="90" x="45" y="30"/>
<operator activated="true" class="text:tokenize" compatibility="5.0.6" expanded="true" height="60" name="Tokenize (2)" width="90" x="313" y="30"/>
<operator activated="false" class="text:filter_stopwords_english" compatibility="5.0.7" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="313" y="210"/>
<operator activated="false" class="text:filter_by_length" compatibility="5.0.7" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="179" y="210">
<operator activated="false" class="text:stem_porter" compatibility="5.0.7" expanded="true" height="60" name="Stem (Porter)" width="90" x="447" y="210"/>
<operator activated="false" class="text:extract_token_number" compatibility="5.0.7" expanded="true" height="60" name="Extract Token Number (2)" width="90" x="581" y="210"/>
<connect from_port="document" to_op="Transform Cases (2)" to_port="document"/>
<connect from_op="Transform Cases (2)" from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="apply_model" compatibility="5.0.10" expanded="true" height="76" name="Apply Model" width="90" x="447" y="120">
<connect from_op="Read Database" from_port="output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="SVM" to_port="training set"/>
<connect from_op="Process Documents from Data" from_port="word list" to_op="Process Documents from Data (2)" to_port="word list"/>
<connect from_op="SVM" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Read Database (2)" from_port="output" to_op="Replace (2)" to_port="example set input"/>
<connect from_op="Replace (2)" from_port="example set output" to_op="Set Role (3)" to_port="example set input"/>
<connect from_op="Set Role (3)" from_port="example set output" to_op="Nominal to Text (2)" to_port="example set input"/>
<connect from_op="Nominal to Text (2)" from_port="example set output" to_op="Process Documents from Data (2)" to_port="example set"/>
<connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="216"/>
</process>
</process>
