<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.11" expanded="true" name="Process"> <process expanded="true" height="190" width="346"> <operator activated="true" class="loop" compatibility="5.0.11" expanded="true" height="60" name="Loop" width="90" x="246" y="75"> <parameter key="iterations" value="10"/> <process expanded="true" height="298" width="811"> <operator activated="true" class="set_macro" compatibility="5.0.11" expanded="true" height="76" name="Set Macro" width="90" x="71" y="45"> <parameter key="macro" value="epsilon1"/> <parameter key="value" value="%{a}"/> </operator> <operator activated="true" class="loop" compatibility="5.0.11" expanded="true" height="76" name="Loop (2)" width="90" x="313" y="75"> <process expanded="true" height="298" width="811"> <operator activated="true" class="set_macro" compatibility="5.0.11" expanded="true" height="76" name="Set Macro (2)" width="90" x="45" y="75"> <parameter key="macro" value="epsilon2"/> <parameter key="value" value="%{epsilon1}"/> </operator> <operator activated="true" class="generate_macro" compatibility="5.0.11" expanded="true" height="76" name="Generate Macro" width="90" x="179" y="75"> <list key="function_descriptions"> <parameter key="epsilon3" value="%{epsilon1}*%{epsilon2}+%{b}"/> </list> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.0.11" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="313" y="75"> <parameter key="macro_name" value="epsilon3"/> </operator> <operator activated="true" class="log" compatibility="5.0.11" expanded="true" height="76" name="Log" width="90" x="447" y="75"> <list key="log"> <parameter key="like this" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <connect from_op="Set Macro (2)" from_port="through 1" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log" to_port="through 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Set Macro" from_port="through 1" to_op="Loop (2)" to_port="input 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator></process>
