<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.0.10" expanded="true" name="Process"> <process expanded="true" height="358" width="748"> <operator activated="true" class="generate_data" compatibility="5.0.10" expanded="true" height="60" name="Generate Data" width="90" x="45" y="210"> <parameter key="number_of_attributes" value="1"/> <parameter key="attributes_lower_bound" value="100.0"/> <parameter key="attributes_upper_bound" value="10000.0"/> </operator> <operator activated="true" class="generate_copy" compatibility="5.0.10" expanded="true" height="76" name="Generate Range Attribute" width="90" x="179" y="210"> <parameter key="attribute_name" value="att1"/> <parameter key="new_name" value="att1_range"/> </operator> <operator activated="true" class="optimize_parameters_grid" compatibility="5.0.10" expanded="true" height="112" name="Optimise Range Attribute" width="90" x="313" y="210"> <list key="parameters"> <parameter key="Fill range attribute.number_of_bins" value="[2.0;10;10;linear]"/> </list> <process expanded="true" height="358" width="744"> <operator activated="true" class="discretize_by_bins" compatibility="5.0.10" expanded="true" height="94" name="Fill range attribute" width="90" x="108" y="29"> <parameter key="create_view" value="true"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1_range"/> <parameter key="number_of_bins" value="10"/> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="aggregate" compatibility="5.0.10" expanded="true" height="76" name="Aggregate" width="90" x="246" y="30"> <list key="aggregation_attributes"> <parameter key="label" value="average"/> </list> <parameter key="group_by_attributes" value="att1_range"/> </operator> <operator activated="true" class="generate_empty_attribute" compatibility="5.0.10" expanded="true" height="76" name="Generate Meta label" width="90" x="380" y="30"> <parameter key="name" value="max"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="5.0.10" expanded="true" height="94" name="Set Meta Label to max" width="90" x="112" y="165"> <parameter key="default" value="value"/> <list key="columns"/> <parameter key="replenishment_value" value="1"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="Average is Prediction" width="90" x="246" y="165"> <parameter key="name" value="average(label)"/> <parameter key="target_role" value="prediction"/> </operator> <operator activated="true" class="set_role" compatibility="5.0.10" expanded="true" height="76" name="Meta Label is 1" width="90" x="380" y="165"> <parameter key="name" value="max"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="performance_regression" compatibility="5.0.10" expanded="true" height="76" name="Performance is difference!" width="90" x="581" y="30"> <parameter key="main_criterion" value="absolute_error"/> <parameter key="root_mean_squared_error" value="false"/> <parameter key="absolute_error" value="true"/> </operator> <connect from_port="input 1" to_op="Fill range attribute" to_port="example set input"/> <connect from_op="Fill range attribute" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Generate Meta label" to_port="example set input"/> <connect from_op="Generate Meta label" from_port="example set output" to_op="Set Meta Label to max" to_port="example set input"/> <connect from_op="Set Meta Label to max" from_port="example set output" to_op="Average is Prediction" to_port="example set input"/> <connect from_op="Average is Prediction" from_port="example set output" to_op="Meta Label is 1" to_port="example set input"/> <connect from_op="Meta Label is 1" from_port="example set output" to_op="Performance is difference!" to_port="labelled data"/> <connect from_op="Performance is difference!" from_port="performance" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate Range Attribute" to_port="example set input"/> <connect from_op="Generate Range Attribute" from_port="example set output" to_op="Optimise Range Attribute" to_port="input 1"/> <connect from_op="Optimise Range Attribute" from_port="performance" to_port="result 1"/> <connect from_op="Optimise Range Attribute" from_port="parameter" to_port="result 2"/> <connect from_op="Optimise Range Attribute" from_port="result 1" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
